how hard can i launch her?.
Old Feb 22, 2012 | 12:14 PM
allout06's Avatar
Default how hard can i launch her?.
Going to the strip this year for the first time. Mods are in sig, stock tranny internally, diamind stage 2 clutch... probably ordering these parts next friday.
MWC 9"
-35 spline lightened spool
-Strange nodular center section-back brace-aluminum daytona pinion support
-3.89 gear
-LCA relo Brackets
-PST 3.5" Drive shaft with forged yokes
MWC SFC weld in
MWC adj panhard bar
MWC adj lower control arms
MWC adj torque arm
MWC cross member w/ driveshaft safety loop and relo bracket for torque arm
Strano sway bars
Strano springs
bilstein shocks (maybe single adj konis)
Founders performance strut tower brace
MSD 2-step
SLP line lock
How hard should i launch her?. What to expect....ET guesses?. Decent setup?
Old Feb 22, 2012 | 02:07 PM
Nitroused383's Avatar
What slicks are you going to use? Depending on the track I'd think WOT from 5000-6500. You will have to play with it, I prefer a quick slip vs a full dump.
Old Feb 22, 2012 | 07:28 PM
stoverz28's Avatar
Go to the track and figure it out for yourself.
Old Feb 22, 2012 | 07:52 PM
35thsscamaro02's Avatar
Lol nice .... Really helpful
Old Feb 22, 2012 | 08:18 PM
mpatton's Avatar
Only one way to find out........
Old Feb 22, 2012 | 08:20 PM
94LT1TA6spd's Avatar
Start low and work your way up.
My $0.02 anyways...
Old Feb 22, 2012 | 08:41 PM
allout06's Avatar
Thanks to thr ppl that were actually helpful. As far as a tire, Im not sure yet. MT or hoosires. Dunno what size i should run Ir what width wheel. 15x8, 15x10... i figured id start at like 2500 and go up. Im not sure how much rpm the stock tranny can take.
Old Feb 22, 2012 | 09:32 PM
Tally TransAm's Avatar
dont even bother with 2500. launch on the two step as high as possible until it starts to spin.
trans should be fine
Old Feb 22, 2012 | 10:44 PM
02LS1ram's Avatar
I would try 4k with a light slip and go from there. I can't talk from
Exp bc I haven't been able to take my car to the track since I put the blower on it. But when it was N/A it worked very good for me an that was on street tires. Good luck
Old Feb 23, 2012 | 07:40 AM
allout06's Avatar
Thanks guys. Im not sure on what size of tire to run either...or what width of wheel. Im not mini rubbing this thing. Its mainly a street car.
Old Feb 23, 2012 | 09:58 AM
LS1RedZ's Avatar
Ive got my 2 step set at 5500 Rpms on my car. Makes 700+rwhp. Dont even try dumping it below 4k cause it will bog like no other. Launch it like you hate it if you want a good number! lol
Old Feb 23, 2012 | 10:04 AM
allout06's Avatar
Haha fair enough. i just don't want the transmission to explode. But apparently it should be ok. With the 2 step, can i just slap it on and use it? Or do i HAVE to have my tune adjusted for it?
Old Feb 23, 2012 | 01:25 PM
I think this is a good idea.
I think you need to be more concerned with axles and rear end though then the tranny, especially if you are gonna run decent tires.
Old Feb 23, 2012 | 01:29 PM
oddwraith's Avatar
I don't know if you can launch hard enough to worry about it breaking with that setup. If it breaks, it wasn't meant to last...So go ***** out and back off as needed imo.
Old Feb 23, 2012 | 10:09 PM
you can launch right off it and get great 60's. cant speak for a blower setup, but turbos can add or pull boost by playing with the timing at the various rpms settings.
just cause i like this vid
[youtube]PHzOcd4zKzk[/youtube]
dont worry about the drivetrain, what you posted is plenty strong, when i was h/c/n20 i would launch just shy of the limiter
Old Feb 23, 2012 | 10:50 PM
02LS1ram's Avatar
I just looked over all the parts your getting and my previous statement has changed. Let her eat. That stuff will have no problem taking the beating!!!!
Old Feb 24, 2012 | 04:08 AM
ren987's Avatar
all good info above for the most part, you will need to keep the rpms higher than 4k and with 3.89 rear gear you will have to ride the clutch a bit to keep from bogging or having to much wheel speed. I could see that set up doing 1.5x 60's with some m/t 28x10.5 stiff sidewalls.
Old Feb 24, 2012 | 02:45 PM
SS-ROB's Avatar
The one thing you need to remember is you can't just put these parts on your car and expect it to work!!! These parts are adj. for a reason. You might launch at 4k and be fine, then 5k and spin all day. Some suspension tweaking and working with it to get it right.
Old Feb 24, 2012 | 04:31 PM
allout06's Avatar
O ya for sure... Ill play with it. ill need a starting place on how to adjust everything...im kind of suspension retarded.. I know what the parts do just don't know how to adjust them accordingly to what the car is doin. Or how much to adjust them....
Old Feb 24, 2012 | 05:51 PM
BOBS99SS's Avatar
Captain Double Post
looked over or just thought it would be better to agree with everyone else lol
