How much timing are you guys running 93 with Meth able to run?
Old 02-24-2012, 10:47 AM
dville_gt's Avatar
Default How much timing are you guys running 93 with Meth able to run?
How much are you turbo guys getting away with on 93 pump and meth injection (80/20)? I haven't started pushing the timing envelope yet, but once I get my short times down thats where I am going to turn for more HP. I am currently at ~11.5* (setup is a s400/lq9).
Also, how much is the jump from 11-12 to say 15-16* worth?
Old 02-24-2012, 10:52 AM
TT-TECH Veteran
Inspector12's Avatar
First off I don't know anyone runing 80/20 meth mixture! But hey if it makes you feel better to add water to it, then I guess your fine then. But when I've been running it I still ended up in the 17* range depending on the car setup CR etc... every degree is going should see a decent gain until you get to a point were it won't gain much most I have seen don't ever pick up anything after 18-20* but most will do that on the dyno and then back it down a couple of degrees for saftey.
Old 02-24-2012, 10:59 AM
Hank Peabody's Avatar
This is from the ken bell website, using a ken bell supercharger obviously but still pretty interesting
Old 02-24-2012, 11:03 AM
dville_gt's Avatar
Wow, 24* seems pretty excessive. Seems like each degree lower becomes more valuable. So 11 to 15 might be worth as much as 14-24
Old 02-24-2012, 11:05 AM
dville_gt's Avatar
Wow, per the chart you are spot on, seems 18 is about point of diminishing returns. Seems I am way light on the timing.
Old 02-24-2012, 11:18 AM
On that Kenne Bell page they say:
"At KB , we set timing at 18° and boost at 9psi for 91 octane. 93 octane allows another 2psi or 2 – 3° spark but NOT both. Higher ECT, IAT and ambient temps will retard spark via the ECM and protect the engine from harmful detonation."
That seems a little bolder than most on a 10.7:1 ls3 but they are relying on the knock sensors.
Old 02-24-2012, 11:25 AM
driven87's Avatar
im planning on running around 19psi and 15 degrees of timing all said and done...i think this page needs a dedicated alky section like the buick boards...
Old 02-24-2012, 11:41 AM
831jd's Avatar
Like too now my limit also ill be on 91 with meth... S480 stock 5.3 tu1 cam victor jr 4l80e....
Old 02-24-2012, 12:10 PM
eb02z06's Avatar
14 degrees at 23 psi, numbers in sig.
Old 02-24-2012, 01:41 PM
buick_lsx's Avatar
i ran 15 degrees on my lq4, s475 on just 93 octane...11-12 psi for 2 years
Old 02-24-2012, 01:47 PM
moehorsepower's Avatar
Wow, You have been running that much timing on 23psi on pump gas, That meth must really work..Thats great to know because I'm contemplating on either meth or nitrous for my setup..
Your setup is about right for no meth..
Old 02-24-2012, 01:58 PM
TT-TECH Veteran
I posted a video of my friends F1 car with a 4L80 that is making 22psi with 93 and meth we are running 17-18* So 14 seemed pretty conservative, but like I mentioned earlier it depends on the set up motor CR etc...
Old 02-24-2012, 02:13 PM
Were you guys all using knock sensors and the ecu pulling timing automatically? Interesting to me to know since I dont use knock sensors.
Thanks!
Old 02-24-2012, 02:15 PM
driven87's Avatar
i know on my car i dont have knock sensors and once i push the envelope just gonna have to be careful. right now im running 15psi and 14 degrees of timing on plain old 93 octane.
Old 02-24-2012, 02:44 PM
Gingervitis Addict
slow67's Avatar
OP, don't forget that the LS3 quoted by Kenne Bell has LS3 heads, which have a different chamber than typical cathedral port heads, so will have a slightly different timing curve (I know they tolerate more timing N/A, so I would expect to see a similarity boosted).
Old 02-24-2012, 02:49 PM
eb02z06's Avatar
Thanks!
I pull timing based on IAT.
My IAT temps on a 160mph pass are in the 110-120 range using a #10 and #15 nozzle.
At this power level I don't rely on the knock sensors-I run the car on the fat side ( you can always see a haze of smoke with the car going down the track) and check the strap on the plug.
Old 02-24-2012, 04:26 PM
TT-TECH Veteran
Thanks!
On his car they do function sorta for a saftey factor, but I usually don't rely on them or run them on any of my car and haven't for a while. But if you looked at the knock sensors they weren't detecting any knock, but the car barley picked up any power from 18* to 20* so I believe we backed it down to 17* as that seemed to be the sweet spot etc... The plugs looked great etc...
Old 02-24-2012, 08:16 PM
cloviskillaxx's Avatar
im running a 70mm stock lq9 air to air 90 pump and aem 75 alky and 25 water and i have zero knock on 8psi and 18 degrees!!
Old 02-24-2012, 08:21 PM
FasTimeSS's Avatar
If ur looking into meth because of ur iats at kdale consider changing ur intercooler. **** meth
wat r u looking for when u check plugs/plug strap? and wat afrs u shoot for? low 11s? thanks im a new ls1 boost adict
Quick Reply: How much timing are you guys running 93 with Meth able to run?
