LT1 Blower sizing
Old Mar 2, 2012 | 08:53 AM
Valkyn's Avatar
Default LT1 Blower sizing
I purchased an engine awhile back and am starting to look around for a blower. The engine specs are as follow:
Block: Stock LT1
Crank: Callies DragonSlayer - Stroke: 3.750
- Main Journal Size: 2.449
- Rod Journal Size: 2.100
- Bob Weight: 1888 Internal
Rods: Oliver Forged I beams - Length: 6.00
Pistons: Diamond w/upgraded pins
- Pin Size: .927
- Diameter: 4.040
- Compression Height: 1.125
- Dome/Dish: -31cc
Main Bearings: MS 909 HXK
Main Clearance: .0024
Rod Bearings: CB 663HK
Rod Clearance: .0021
Rings: Total Seal TNT 1/16 1/16 3/16
Top Gap: 26
2nd Gap: 22
Deck Height: -.006
Block Height: 9.000
Torque Main: 70 w/ moly / 60ft.lbs.
Torque Rod: 70ft.lbs w/ moly
The heads are ported AFR 227s with Jessel comp shaft mounted rockers that flow:
.2 138/103
.3 206/139
.4 255/173
.5 293/198
.6 308/210
.7 313/229
.8 314/237
chamber size: 56cc
Compression should be ~8.8:1
The cam specs are:
Duration @ .050" 236/242
Lift .572/.576 (1.65/1.6)
Lobe Sep. 115
Advance +4
Intake manifold is a ported Edelbrock LT4 airgap. I have not decided on intercooler type yet. I am leaning toward air to water. Meth injection will be utilized.
My power goal is 800 RWHP. Does this seem realistic for the parts? I want a good balance between power and longitivity.
So I am trying to figure out what size blower I should run on this. The price of the D-1SC is attractive but I'm afraid I would be maxing out the blower and belt slip will become an issue. I am tentatively thinking an F-1A is my best option; it should meet my power goals without being pushed too hard and it does not have the fitment issues the F1-C/R do (block has to be ground to clear).
It sounds like there are going to be alot of F-1Rs on the market since the new F-1X is coming out, maybe it would be the best option pricewise. Would the R meet my goals or would it be overkill?
Also what belt setup would you guys recommend? would a 12rib be good or go with a cog drive?
Any feedback is appreciated!
Old Mar 2, 2012 | 09:49 AM
RealQuick's Avatar
You got a stout motor going together. I don't think a D1SC will be enough, but I think the F1a is plenty and will get you there.
I would email Silas (The SRZ) as he is thinking about selling his F1a complete setup (I think it has ~1k miles on it).
Old Mar 2, 2012 | 10:50 AM
Valkyn's Avatar
If i go nuts and decide to crank up the power how much HP would the F1a support?
Old Mar 2, 2012 | 02:18 PM
RealQuick's Avatar
LSX guys have gotten 1000rwhp+ out of it, so I would think 900rwhp is doable with a stout LTx.
Old Mar 2, 2012 | 04:18 PM
Blackbirdws6's Avatar
F1-A will get you there.
Old Mar 4, 2012 | 07:19 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I wouldn't go any smaller than thew F-1A. Mike Harvey's '95 runs very well with an F-1C, shown here. http://www.youtube.com/watch?v=EdsOf...layer_embedded
He remade the bracket to eliminate flex that he was having, he made an extra one and you might want to pm him on it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 6, 2012 | 02:46 AM
yonerhottlt1's Avatar
Vortech YSI?!
Old Mar 9, 2012 | 02:55 PM
Valkyn's Avatar
Originally Posted by yonerhottlt1
Vortech YSI?!
I've been doing more research lately and the YSI seems to have quite a few fans.
I was leaning toward the F-1R but I have read that it really likes to be spun fast; I'd like to keep my engine under 7000 RPMs.
Is this just a myth? All blowers are going to make more boost the faster you spin them I assume. Do some make better boost across the RPM range or are they all linear?
Old Mar 13, 2012 | 11:14 AM
LS1Tech Sponsor
Some do build boost better, a lot of it depends on the impeller design. Bob
__________________
Old Apr 9, 2012 | 09:55 AM
Valkyn's Avatar
I've been doing more research, still not sure on which blower but I've been looking more into the brackets. What do you guys think would be the best for a street strip setup, a 12rib or a cog?
The only cog bracket ive seen for an LT1 is House of boostsetup (which seems pretty pricey and I havent found much feedback on). Are there some SBC low mount brackets that would work on the LT1?
