How much power will ID1000 injectors support in FI.
I know it depends on fuel, pressure etc, but what is the max HP you can get out of ID1000 injectors on pump or E85?
Single turbo 5.3 build if that matters.
From what I have heard for an 8 cylinder, expect 1 HP per CC with E85.
So,ID1000's should be 1000 CC injectors so 1000 HP at the crank.
I was told that the 1600cc's that I have can support 1600 HP with E85...but I do not have a turbo near big enough (nor the motor, LOL) to make that happen.
The good thing, with those injectors & E85, you should not need METH.
Just good tuning and E85 will make awesome power.
it really depends on fuel pressure. What fuel pump(s) you gonna use? Whats gonna be your base?
@43.5 base, 0.85 BSFC, 85% duty, around 800HP
@58 base , 0.85 BSFC, 85% duty, around 900HP
http://www.rceng.com/technical.aspx
triple hat Fore return with ID1300x installed next week.
