My twin turbo shopping list....Comments/advise welcome
I'm starting to piece together my twin turbo kit for my 02 Fbody. My car will be a street/strip with a forged LS3 hoping to put out at least 1000RWHP thru a TH400 and 8.8...all on E85. So far I have both turbos (Ebay GT45s) and a pair of truck manifolds. I'm now looking at purchasing a few other parts and I want to know if my list is on the right track before I start breaking the wallet.
Heres what my shopping list consist of
1 Threadstone TwinTurbo Intercooler TRTTC9
Core Size, 25" X 9" X 3.5"
1-3" outlet and 2-2.5" inlets
Outlet is angled 15 degrees
1950 CFM flow rate
1300 HP efficient
2psi pressure drop at 1950cfm
2 OBX 38mm WGs w/ V-band clamps
1 OBX 50mm BOV
4 downpipes w/ electronic cutouts
2.5 turbo-to-intercooler pipes
3.0 Intercooler-to-intake pipe
2.5 Exhaust manifold-to-turbo pipes
Misc. lines for oil supply and drainage.
Silicone couplers.
V-bands for solid connections
Can you guys please go through my list and tell me what you think. Are charge pipes too small or intercooler too small, etc, etc. If you would change anything can you please tell me why and what to replace it with. Any feedback will be greatly appreciated.
Thanks guys,
BTW, I will be documenting everything every step of the way.
1950 CFM flow rate
1300 HP efficient
1 OBX 50mm BOV
Silicone couplers.
Thanks guys,
Is the outlet on that Treadstone IC 3" I.D. or 3" O.D.? I had an IC that had a 3" O.D. With the cast end tanks, that made the I.D only 2 5/8". That is too small for 1000whp. In my opinion even 3" I.D. is too small for 1000whp but clearly the IC states it is efficient at 1300 fwhp so... yeah.
For your down pipes, you don't need to go a full 4" if you are running two of them. It won't hurt anything and bigger is always better when it comes to down pipes, but sometimes room can be a problem. I would not go smaller than 3" though.
You could do 2.25" IC pipes going to the IC and it would be a better match for the single 3" outlet as far as square inches is concerned. It would help with spool a little tiny bit too. But personally I would stick with the two 2.5" hot sides and probably go up to a 3.25" cold side.
As for the DPs I was thinking of doing 4" pipes and then downgrading them to 3.5" or even 3.0" pipes once they pass the electronic cutout. This way I get max efficiency when the cutouts are open. Plus, as you stated, room can be a problem.
As for the turbo-to-IC pipes you say 2.25" pipes w/ the 3" outlet would be a better match. So if I keep the 2.5" pipes and upgrade the IC outlet to 3.5" would this be a better match?
Are the OBX units crap? Do you have experience with them? What other WGs do you recommend that are pretty cheap? Also, is the size I have (38mm) good enough for my power levels?
I'm not sure if the 3" is I.D. or O.D. Here's a link to the IC....http://www.treadstoneperformance.com...2C+GM%2C+Viper I just sent them a email asking this so hopefully they can get back to me soon. I figured 3" was too small. I was hoping I can get a 3.5"-4.0" outlet O.D. If it's 3" O.D. I can cut out the outlet and install a 3.5" or 4.0" O.D. instead and have it tig welded. What do you think?
As I stated, my I.C. had the 3" O.D. in/outs on it. I cut them off and TIG welded on some 3 3/8 I.D. (3.5" O.D.) V-band in/outs. So yes that would be a viable option.
Cant really see it in this picture because the Vband clamp is in the way... it's there.
![](http://i77.photobucket.com/albums/j68/SATANZ31/003-2.jpg)
As far as using OBX waste gates or just ebay gates in general... I have never had a name brand waste gate. I have also never had a problem with my waste gates. In my opinion, it is pretty hard to **** up something as simple as a valve and diaphragm.
Name brand is good. Name brand is expensive.
Sounds good. I'm still waiting on a response from ThreadStone so hopefully they get back to me soon.
Any other things that would help my shopping list?
Also, I know an X-pipe helps with exhaust scavenging on N/A but does that apply to turbos as well?
Thanks again for all the advise guys. I really appreciate it
