Holley Hi Ram Intake
Old Nov 15, 2012 | 07:58 AM
  #181
lazaris's Avatar
Originally Posted by jridenour31
600°!?!? I don't even see how that would be possible.
X2. If that were so I could not imagine what an intake (stock style) with a much smaller plenum volume would equate to. This Holley Hi-Ram closely mirrors a sheet metal which are know to have the most equal air distribution compared to conventional intakes.
Old Nov 15, 2012 | 10:28 AM
  #182
Ksths2's Avatar
I've got a question..... mine is hte 300-116 (LS3/L92 version) and i'm still not 100% on what is wrong with these intakes? Everyone keeps talking about the castings & injector alignments, depths, etc.
Oh btw if anyone was wondering if wanting to install on a C5 vette... have a sawsall handy
(This is before I chopped 2" from the cowl, its moved 2" ahead)
It looks like a 4.5" cowl hood will clear the highest point
All of my injectors line up correctly from fuel rail to base & the depths seem to be all the same but, I installed a mock up FAST 36lb injector and it looks to me that if the injector has much of a "fan pattern" the gas will hit the ID of the injector bore? this shot is deceiving because that injector is about 1" up inside the injector hole....What do you think?????
Here is the same injector side shot with the injector bottomed out in the rail & in the intake base
Old Nov 15, 2012 | 01:23 PM
  #183
ShredSled's Avatar
Ksths2, I see what you mean about the injector being recessed way up in that bore... I'd be curious about it altering the injectors spray pattern too, and instead spraying the walls of that recess. Would need to confirm how far out, or how wide, that "fan" pattern sprays.
whaaaat? I agree, don't see how that could even happen.
I could see how this intake might be a big heat-sink vs. oe/fast, though...
Old Nov 15, 2012 | 02:29 PM
  #184
Ksths2's Avatar
FYI I just got an email back from John at "Fuel injection connection" and he said i would need an "extended tip" injector to fix this issue.....good thing I hadn't bought my injectors yet lol
Old Nov 16, 2012 | 04:56 PM
  #185
ShredSled's Avatar
WHAT, really?!??
So running this Holley Hi-ram essentially requires new custom injectors? That significantly jacks up the cost of this swap.
Old Nov 16, 2012 | 08:36 PM
  #186
Sarg's Avatar
I can throw a couple injectors in this weekend and see what they look like with "standard" ls1 injectors.
Old Nov 16, 2012 | 08:39 PM
  #187
coolmanvette75's Avatar
What injectors are the COPO cars running?
Old Nov 18, 2012 | 05:52 PM
  #188
Sarg's Avatar
Installed (well not final, but as it will sit for now) and on the car. My impressions....casting was a tad sloppy on the inside, I really don't like how they had all the bolts come up from the underside and have exposed holes on the top. It would have looked much nicer if the bolts holding the two halves together come in from the top rather than under it. It is about impossible to get a torque wrench on some of the bolts unless you have a little tiny 1/4" torque wrench and even then you might run into some issues. But I DO love the way it looks in the car (minus the bolt holes...might make some kind of a cover or something).
Old Nov 18, 2012 | 07:54 PM
  #189
The Alchemist's Avatar
UNDER PRESSURE MOD
That's killer looking.
Old Nov 18, 2012 | 09:46 PM
  #190
edge04's Avatar
This looks badass. I really like Nelson's alien intake but that is HUGE money. Going to take some measurements and see if this will fit under the hood of my 66 Nova
Old Nov 19, 2012 | 10:36 AM
  #191
Ksths2's Avatar
shredsled, I'm still researching on the "custom" injector depth issue... I'm betting the stock size would work but still not sure if it if would be an issue if the fan pattern would actually hit the sides or not.
Old Nov 19, 2012 | 02:52 PM
  #192
Ksths2's Avatar
Here are the pics of the "MINIMUM" of how much is needed to remove out of the cowl & the plastic wiper cover on a C5 Vette.
as you can see I might need to remove a bit more depending on what fitting I'll need for the brake vacuum & MAP sensor - but it does look like its possible to run both of the wipers
Also, the fuel rails are so big on this that I had to remove alot more than first expect to make room for them & the fittings coming out of the back of them as well
And last I couldn't resist a shot of it 100% fit/installed
Old Nov 19, 2012 | 03:31 PM
  #193
raymond mckinney's Avatar
You guys think it would fit under a 67 Camaro factory cowl hood?
Old Nov 19, 2012 | 08:47 PM
  #194
transdam's Avatar
It fits under my stock chevelle hood. Holley Hi Ram Intake-2012-09-16_12-58-38_913.jpg
Old Nov 19, 2012 | 11:35 PM
  #195
jdpepper's Avatar
no, a 4" cowl might work or if you turn it around and have the tb facing backwards it might fit.
Old Nov 19, 2012 | 11:37 PM
  #196
jdpepper's Avatar
another shot without the top
Old Nov 20, 2012 | 12:52 AM
  #197
baggins's Avatar
Have the casting issues been resolved on the ls3 version?
Old Nov 22, 2012 | 12:24 AM
  #198
BlackWS666's Avatar
bumping this up for info on the injector needed.
Old Nov 22, 2012 | 10:16 AM
  #199
SKULL's Avatar
ksths2. personally i would get a stock hood or a 2 inch cowl hood. cut the hood and let the intake stick through the hood lol having a 5 inch cowl hood on your vette.... you wouldnt see ANYTHING. thats what i wanna do if i ever used that intake on a c5
Old Nov 22, 2012 | 10:40 AM
  #200
Reher Morrison's Avatar
Default efi ram
I have been looking at the one I have in the shop for a COPO Camaro stocker we are working on. If you cut off the front, lowered it and made a sheet metal top you could get it down to 10". Still tall but a 2.5" reduction in height. Granted, it might take some top end power out of it then again, it might not hurt it it all. Until someone is willing to test it like this we will never know.
