Holley Hi Ram Intake
Old Nov 22, 2012 | 03:44 PM
  #201
edge04's Avatar
Any more info on the injectors? Not sure I will get more out of this intake compared to my current edelbrock but really like the look. My injectors are from precision turbo, they are 95 lb 1000 cc. Will they work?
Old Mar 17, 2013 | 03:42 PM
  #202
223HAWK's Avatar
Did I miss if you made it fit with the hood or what hood did you go with?
Old Mar 17, 2013 | 07:28 PM
  #203
westtexasbuff's Avatar
Only hoods that will fit are the VFN 4" and 5", and the Joe Van O Hood (heard it's hard to get in contact with him though and it takes months to get a hood from him, plus freight from Canada isn't cheap).
I think I'm going to take a stock WS6 hood to a body shop and have them cut and raise it a few inches. I think it'd look better than the VFN hoods.
Old Mar 17, 2013 | 07:43 PM
  #204
223HAWK's Avatar
Dang well I have the lift off 4in now... I was thinkin about makin the car a lil less race carish and but my stock hood back on.
Old Mar 17, 2013 | 08:36 PM
  #205
BlackWS666's Avatar
Im in the same boat. Have a VFN bolt-on WS6 hood, and am going to run the hi ram. Im positive that its going to hit my hood so i will have to put a bubble in it for clearence. When i get to the point where im fitting the hood i can take measurements and pictures to show you all what exactly needs to happen to fit the intake onto the car with a stock sized hood.
Old Mar 18, 2013 | 03:25 AM
  #206
Please post pics when you do!
Old Mar 18, 2013 | 10:02 AM
  #207
Texas_WS6's Avatar
I used the VFN 5 inch sloped hood. Fit it perfect. I have about a quarter inch from the top of the intake to the hood. I plan on atting a little rubber tab under the hood so the intake will support it some. Keep in mind my setup is solid motor mounts.
I did have to trim the cowl all the way to the windshield. I did not cut the windshield any. I have enough room from the windshield to the manifold to just let the throttle cable pass. When I cut the cowling it opend up the steel box of the iner dash. I then built a custom coil rail that holds all 8 coils and mounted them in the dash and ran custom length plug wires. SO now the coils are out of sight.
I will try and post some pics. My laptop crashed and I lost the ones I had on here.
Old Mar 18, 2013 | 06:58 PM
  #208
slvrbackls1's Avatar
Not sure if you guys have seen this yet on yellowbullet. Looks like someone is trying to come out with a built in a2w between the top and bottom.
http://www.yellowbullet.com/forum/sh...d.php?t=549765
Old Mar 18, 2013 | 07:24 PM
  #209
Sarg's Avatar
Yup, good stuff. They already have folks trying to pre-order and it is not even done or tested, lol.
Old Mar 19, 2013 | 03:10 AM
  #210
Anchor's Avatar
Damn, that's an awesome idea. And i just purchased a treadstone unit too
Doesn't mention pricing yet. But i'd definitely be in on that setup.
Old Apr 10, 2013 | 08:22 PM
  #211
Midnight's Avatar
Dudes, stop trying to squeeze this giant intake under the hoods of your vettes/camaro's. HERE is what you need, it's the new Holley mini-ram intake based off the Hi-Ram, only with shorter runners. Check it out.
http://www.hawksthirdgenparts.com/pr...-Manifold.html
  #212
Midnight's Avatar
Old Apr 10, 2013 | 08:40 PM
  #213
Reject's Avatar
check out page 7 of this very thread
Old Apr 10, 2013 | 08:53 PM
  #214
PRAY HRD's Avatar
still have to hack the cowl up and likely ditch your wipers......
https://ls1tech.com/forums/generatio...-intake-3.html
Old Apr 11, 2013 | 12:32 AM
  #215
coolmanvette75's Avatar
So is the general consensus that the cathedral port version WILL NOT fit an fbody like an ls3 version would after cutting and everything?
Old Apr 11, 2013 | 01:01 AM
  #216
It would fit if you cut the windshield. Cathedral versions are 1/4" taller than LS3 versions. Mine (LS3) sits REALLY close the windshield probably like a 1/8" or less.
Old Apr 11, 2013 | 01:02 AM
  #217
notsureifsrs.... those mini-rams are **** compared to the hi-ram.
Old Apr 11, 2013 | 06:55 AM
  #218
MikeFSKSpeed's Avatar
For a boosted setup, The Hi Ram is the way to go, Much more runner volume then the mini ram.
I got 25 Cathedral Hi Rams in stock if anyone needs
Old Apr 11, 2013 | 10:24 AM
  #219
Ksths2's Avatar
I think the mini looks like crap compared to the hi-ram and from what I've heard I'm banking on the gains in performance for the hi-ram. Can't wait!
Old Jul 28, 2013 | 06:55 PM
  #220
locospl's Avatar
Anyone with before and after dyno numbers when swapping to a high ram? Any more pics in a f body with hood on?
