Holley Hi Ram Intake
Old Nov 9, 2012 | 07:07 AM
  #161
Stangkilr's Avatar
The Hi-Ram is the ONLY way to go for the money. Not the Mini Ram. GM would not use any intake on their top shelf car "COPO" if it didnt work. You know they have done hours of testing.
Old Nov 9, 2012 | 09:22 AM
  #162
SKULL's Avatar
so will someone please find out what it takes to get either regular or mini ram to fit a c5(z) k thanks
Old Nov 9, 2012 | 10:34 AM
  #163
qqwqeqwrqwqtq's Avatar
When the dual 4bbl dual plane intake came out (that they use with the miniram) I ordered one for my Cadillac.
Sent it back upon receiving it. Internally, it looked like the worst intake manifold I have ever seen. Would be surprised if it didn't lose at least 50hp to a stock intake.
Old Nov 9, 2012 | 10:44 AM
  #164
Stangkilr's Avatar
I was told by a pretty good source the mini ram sucks, dont buy it. Buy the hi-ram if it will fit.
Old Nov 9, 2012 | 11:02 AM
  #165
SKULL's Avatar
thats too bad pictures look promising
Old Nov 9, 2012 | 12:37 PM
  #166
TheLS1Lover's Avatar
Gotta agree with the consensus.. That mini ram looks poopy. Run the factory/FAST or the High Ram, maybe even the Pro Flo..
  #167
Reject's Avatar
aw i was looking forward to the mini so i could keep my wipers
Old Nov 9, 2012 | 12:39 PM
  #168
The Alchemist's Avatar
UNDER PRESSURE MOD
Yeah, I too want to keep my wipers as well, just in case.
  #169
Reject's Avatar
i just want them because street car
Old Nov 9, 2012 | 01:10 PM
  #170
UNDER PRESSURE MOD
Yeah, inspection overlooks a lot, but not having windsheild wipes isn't one of them.
Old Nov 9, 2012 | 11:40 PM
  #171
PRAY HRD's Avatar
i have a ton of respect for your input Jim! I'm out! My wipers are gone and rainX is on so my money will go to the tall when it's time.
Old Nov 14, 2012 | 12:27 PM
  #172
slow67's Avatar
Gingervitis Addict
Super chevy tested it on a dyno (vs a victor jr, both carbed) and it equaled it on top and just destroyed it down low.
Old Nov 14, 2012 | 12:29 PM
  #173
Reject's Avatar
Have a link maybe?
Old Nov 14, 2012 | 05:08 PM
  #174
ShredSled's Avatar
Originally Posted by Texas_WS6
I took my Hi Ram and had it flowed last week on my heads and a set of Mass Motorsports LS3 Small Bore heads.
So far it looks like it is a very good peice. My old ported GM Performance Single plane intake dropped the flow on my ported heads about 10 percent but only dropped the flow of the Mass LS3 Small bore head about .5 percent (these are very good heads for the small bore engines (LS1 bore)). Keep in mind the GM intake did not have a TB on it but it does have an elbow.
Something else to note, the stock LS3 manifold kills my head and the Mass Motorsport LS3 Small bore head, and the Fast intakes? Well they are better then stock but no were as good as the single planes even with the elbows, at least on these two heads.
The Hi ram did not reduce the flow numbers of either head and it had the 92mm TB installed on it! I left it with the shop becasue they wanted to flow it on a set of Mass Motorsports LS7 heads he had there. I will post up the results of that test when he is done.
So far the HI RAM will at least keep up with m heads and we will see this week what it can do on the MMS LS7 head. I would say the improvment through the intake will be worth the trouble to modify the car to fit it.
good info, thanks for posting up your experience with it... I too have been eyeballing some Mast rect. port heads, but $$ I do not have at the moment.
I was thinking of pairing them with the new Hi-ram when I save up some more cash over winter.... COPO truck, anyone? haha.
Old Nov 14, 2012 | 06:27 PM
  #175
EvilStang's Avatar
STF Veteran
I bought this intake for my build and haven't put it on yet. I heard from the justin smith that this intake is having issues with the egts. what i was told is that he has done quit a few egt logs from a motor with the intake and the cylinders were all over the place. Some as big as 600* difference. Is anyone else having this problem? or seen anything similar? im very curious as i may be switching intakes now because of this
Old Nov 14, 2012 | 07:32 PM
  #176
UNDER PRESSURE MOD
Super Chevy tested which one? The high ram or mini ram?
Old Nov 14, 2012 | 09:29 PM
  #177
jridenour31's Avatar
600°!?!? I don't even see how that would be possible.
Old Nov 15, 2012 | 12:26 AM
  #178
SKULL's Avatar
Because race cars
Old Nov 15, 2012 | 04:34 AM
  #179
Sarg's Avatar
Curious what they are switching from and if they are trimming individual cylinders before or after?
Old Nov 15, 2012 | 06:46 AM
  #180
Texas_WS6's Avatar
I expect to get my intake back from the porting shop that I loaned it out to after Thanksgiving. He has probably flowed it on the Mass LS7 heeads by now but I have not checked in with him yet. I will post up a brief report on his results in the next week or two.
I will look into installing 8 EGT on my setup and see if I can get any results. But I do not plan to fire this thing up until after Christmas.
I believe Kevin at Virginia Speed has done alot of work with the Hi Ram. Maybe he could give us some insight on the EGT question posed here.
