Aeromotive 13301 ok for my 5.3 twin turbo??
Hey guys like title says I have a brand new Aeromotive 13301 bypass regulator. Just wanting to make sure this is going to work. Some more info I have a stock 5.3 with ls6 cam and springs added a ls1 intake and going to run 65# inj with the E-bay 57mm twin turbo set-up. thanks guys
Thats a good regulator for what you are doing but if I had to build my fuel system. I would use a regulator that would come off both rails and feed both rails from my pump so I wouldn't have the regular crossover style.
Don't get me wrong, If I had the crossover style then thats what I would just use but to build it from scratch it would be different.
The 13113 is the one I would use on the setup i described.
Cool, I really don't know what I'm doing. I bought this and a aeromotive A1000 fuel pump a 100 micron filter and a fuel pump controller. any suggestions or pic on how to hook all this up would be great. I was looking at the regulator last knight I do not have any instructions so what one is the In or out or return ports? like I said any help would be great this is my first time doing a fuel system of this caliber.
It certainly is not essential to do it like that.
The regulator can be installed anywhere between the pumps and the end of the fuel rails. Pressure within the line will still be controlled and maintained.
Doing a full flow setup through the rails may have some benefits over a setup that sees a dead end fuel rail.
But the dead end fuel rail with the regulator before also has it's benefits ( cooler fuel maintained )
Both are valid install options though.
Ok so do I need to run to both fuel rails at the back or do I run to one and plug the other side? In the pic it shows running in both fuel rails at the rear and regulator in front has lines going to both also. This doesn't create like a back flow or flow from both directions? Like I said before this is my first ever fuel system I'm planning on sump-ping the tank. Do I run into the 100 micron right out of the tank then to pump then another filter on the other side of pump then up to both fuel rails on the back side? If so what size post filter do I need another 100 or like a 10 micron? Sorry for all the questions I'm just totally new to fuel inj and fuel systems of this caliber. Thanks again guys for all the help. Josh
How you plumb them is entirely up to you.
Yes splitting and feeding to each rail is better, but not essential. You could flow up one and into the other if you wanted.
100 micron pre pump is quite normal. And a smaller say 40 or 10 micron after.
That said, Ive been running for years with just a 100 mic Aeromotive before my pumps with no problems.
