99t66ls1's finished t76 system
Old Mar 24, 2004 | 08:09 PM
AaronL's Avatar
Default 99t66ls1's finished t76 system
Here are the pictures after everything was coated and installed.. (p.s. maybe a little more credit should be given to the fabricator.....)
Attached Thumbnails 99t66ls1's finished t76 system-camarocooler7.jpg   99t66ls1's finished t76 system-camarocooler3.jpg   99t66ls1's finished t76 system-shinyexhaust.jpg   99t66ls1's finished t76 system-shiyheader01.jpg   99t66ls1's finished t76 system-chamaro07.jpg
Old Mar 24, 2004 | 08:21 PM
InvisibleSun's Avatar
Looks Great!
Old Mar 24, 2004 | 08:34 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice, is the radiator recessed into the core support?
How about a rundown of the drivetrain.
Old Mar 24, 2004 | 08:51 PM
AaronL's Avatar
I cut and re-welded the radiator end tanks in further to fit in between the frame. It's 99t66ls1's car, I just made the headers, y-pipe, downpipe, intercooler and intercooler plumbing. He did the rest of his car ,built pretty badass, he would have to tell you everything he's done to it. I cut out the lower radiator support, and we both re-fitted it to run vertical.
Old Mar 24, 2004 | 10:49 PM
Jammer's Avatar
Cut the flange in the middle and drill out the header bolt holes to allow for expansion...something to think about or you may sheer the bolts/
Old Mar 24, 2004 | 11:21 PM
69firebird's Avatar
very nice, any plans to sell the kit? or just a buddy thing?
could you take some more detailed pictures of how the radiator sits in there, i would like to do that to make some room
thanks
ed
firebird455@onebox.com
Old Mar 25, 2004 | 02:07 AM
BIGBOS's Avatar
Thats a nice little setup, stock motor?
Old Mar 25, 2004 | 06:46 AM
AaronL's Avatar
Probably not going to sell the kit. It was a lot of work for the both of us to put everything together the way it sits (high mount alternator,no a/c,radiator relocation,bumper trimming on the back side, vacuum canister relocate, box in the radiator narrower & relocate/reposition lower radiator hose inlet to radiator, box in fill neck inlet and make inline fill neck.. etc. etc.
The car isn't at my house anymore to take anymore pics, but I just cut the upper support flush before it starts to roll back under, snugged the radiator up to it, welded on mounting tabs, cut the lower support off flush with the frame,then we made some side plates to drop straight down from the frame and used the existing bottom radiator support but clocked back 20 degrees or so to make it vertical...
buddy thing?
thanks
ed
Old Mar 25, 2004 | 06:47 AM
AaronL's Avatar
no, he's got the motor cammed and stuff, check out his first posts on 'pics of my t76 setup a few pages back (99t66ls1 username)
Old Mar 25, 2004 | 11:26 PM
99t66ls1's Avatar
Aaron does deserve much of the credit i do not have the fabrication skills he does. It was basically designed how i wanted it and then he fabbed it while it sat there and watched. The motor is stock crank, pro mod rods, diamond forged boost pistons, cometic hp head gaskets, comp cams 224 218 .568 .563 on a 114 lsa, 69 firebird i will try to send some closer pics when i get a chance, hows the downpipe working.
Old Mar 26, 2004 | 05:27 AM
69firebird's Avatar
havent gotten it on yet, but should be ok
thanks
ed
Old Mar 26, 2004 | 08:17 AM
MIGHTYMOUSE's Avatar
im impressed, looks like a gread job and a lot of hard work, should flow very well (obviously)
Old Mar 26, 2004 | 08:47 AM
1BadAzzWS6's Avatar
thats awesome...nice job!!! What kind of numbers should you see out of a setup like that?
Old Mar 26, 2004 | 09:08 AM
Whistler's Avatar
Sawzall and Welder Mod
Congradulations to both of you! A project like that takes a lot of time, planning , patience, and cash! Best of luck with it.
