Divided T6 or no?
Old Apr 15, 2012 | 05:47 PM
MUSTANGBRKR02's Avatar
Exclamation Divided T6 or no?
I am about to start building my T6 kit but am wondering as to which way to go? I have a open T6 flange already but I only want to build this kit once. Turbo is a divided S480 1.32 AR and a 370 CI motor. 4l80e.
Old Apr 15, 2012 | 06:38 PM
Bobsmyuncle's Avatar
If ur gonna use a spool valve, do it. If u aernt, I still would. Either knife edge it for flow, or keep each bank totally separate.
Old Apr 15, 2012 | 06:42 PM
JAX04's Avatar
i have a theory about that, lol.
I cannot help but think that Borg Warner put it their for a reason, if your not gonna use a spool valve, i would do it 100% divided. Just my .02, take it for what its worth
Like i said, They had to have a reason to use it.
Old Apr 16, 2012 | 05:08 PM
From looking around I don't see much difference in performance between the two. I think I will just use the open flange that I have.
Old May 27, 2012 | 06:00 PM
Camaro9969's Avatar
I agree!! Borg Warner has made tturbos for years their engineers are probably a lot smarter than us so there must be a reason for the divided housing. Which way you end up doing it??
Old May 27, 2012 | 06:45 PM
i used the open flange
Old May 27, 2012 | 06:50 PM
Cam72aro's Avatar
What size is the s480? Is it 88mm? I am doing a gt 91 on my car as we speak. Good luck with the build.
Old May 27, 2012 | 08:20 PM
96mm with the 1.32 AR
Old May 27, 2012 | 09:03 PM
Cam72aro's Avatar
Is that 96mm on both sides?
Old May 27, 2012 | 09:14 PM
JAX04's Avatar
I def stuck to the divided flange, and i have to admit, it looks awesome, and from messing around in neutral in the driveway tonight, i think its going to come up on boost pretty quick,
If i was bored, and had aspirations of amazing-ness, id fab up another crossover, identical to mine now, except with merged pipes... and see what happens... lol
Old May 28, 2012 | 01:15 AM
Fbodyjunkie06's Avatar
The 80 denotation after the 4 let's you know that it is a 80mm compressor wheel on the 400 series chassis.
Old May 28, 2012 | 10:49 AM
EvilStang's Avatar
STF Veteran
pics of the set up?
Old May 28, 2012 | 12:22 PM
I'll grab some in a bit with the camera and start a thread.
Old May 29, 2012 | 08:38 AM
Camaro9969's Avatar
Well whats good is i guess we will see which spools better i did the divided (twin scroll) set up and you did open flange. I'm just lucky i got a buddy who is a great welder or i wouldnt of been able to do it that way.......Nicely anyways.
