"Boost by gear" controllers?
Old Apr 17, 2012 | 01:19 AM
salemetro's Avatar
Default "Boost by gear" controllers?
I've been searching the net for a "boost by gear" solution for a near-future upgrade for my Miata swap....I'm not finding much in the way of recent/current products.
Are any of you guys using a controller similar to the old Innovative MSBC-1? I'm wanting something that reads "gear selection" based on the VSS, as the car is a 6-speed. Hell, I'd even go for an MSBC-1 IF I could find one new in the box.
Any thoughts?
Old Apr 17, 2012 | 02:34 AM
itsslow98's Avatar
eboost 2 is very popular.
Old Apr 17, 2012 | 07:54 AM
runsfromdacops's Avatar
I just got the eboost 2 for my car but i dont see how it can do boost by gear without a vss input. Im hoping that it can but i just dont see how with only rpm
Old Apr 17, 2012 | 08:50 AM
Tiago's Avatar
eb2 can't use VSS. It has to have a 2 wire logic done by 4 switches to dictate 1-2-3-4 gear position mechanically on the shifter.
in any case, I don't think you want VSS to dictate the boost level. If you spin, the VSS goes up, boost goes up, spin more, etc. You want something independent of rear wheel speed, front wheel speed would be ideal.
AMS1000 can do it by time, VSS, or by switches also.
Old Apr 17, 2012 | 09:25 AM
turbocamaro125's Avatar
Any thoughts?
Speed Inc sells the Exile controllers for 649.99
Old Apr 17, 2012 | 09:33 AM
Sarg's Avatar
Apexi avc-r has per gear boost for 5 gears.
Old Apr 17, 2012 | 11:56 AM
salemetro's Avatar
in any case, I don't think you want VSS to dictate the boost level. If you spin, the VSS goes up, boost goes up, spin more, etc. You want something independent of rear wheel speed.....
Exactly! I have an eboost2 in my fbody....not what im looking for. I'm thinking that use of a front abs sensor could be fabed up to serve the purpose somehow. I'll look into the other controllers suggested....
Thanks guys!
Old Apr 17, 2012 | 12:08 PM
slow67's Avatar
Gingervitis Addict
Louis had a solution for the EB2 guys a while back.
most honda ecus do boost by gear based on rpm vs vss. That the only real way to do it
Old Apr 17, 2012 | 12:12 PM
jimbos'ss's Avatar
hks evc 6
eboost2
ams1000
i believe those are the only options for boost by gear. I used to use the evc 6, was a pain to get set up. love the **** though
Old Apr 17, 2012 | 01:23 PM
The avcr is a pita to setup aswheel but works great after that
Old Apr 17, 2012 | 02:33 PM
salemetro's Avatar
Originally Posted by jimbos'ss
hks evc 6
eboost2
ams1000
Looks like the EVC6 is the solution....definitely a nice piece. Thanks for the suggestion!
Old Apr 17, 2012 | 04:38 PM
stngtamr29's Avatar
Ams 1000
Old Apr 18, 2012 | 12:48 PM
jimbos'ss's Avatar
No problem, I loved the one I had on my last car once I got it all set up.
Old Apr 18, 2012 | 01:16 PM
skinnies's Avatar
The ams1000 boost by gear setup is for bikes, not easily done on cars, although it can be done, just not easy like people think, most who recommend it have never even owned one or fully read the manual.
Old Apr 18, 2012 | 01:48 PM
KILLER-LS1's Avatar
Lingenfelter makes an adapter to let you use boost by gear by plugging into your VSS. Im going to run that on my eboost2
Old Apr 18, 2012 | 03:18 PM
salemetro's Avatar
Problem with that, is that front wheel speed is ideal. When breaking traction with a VSS setup, wheel speed increases (obviously)....but worse, so does boost. Unless, that is, you're able to get a signal from a "non-power-driven" wheel.
Interesting information with regards to the adapter....I'll check it out.
EDIT
I checked it out... Part Number: L460050000 However, I'm not sure if it could be hooked up to something like a front wheel ABS sensor. My car does not have ABS, but I could swap one of the front knuckles for one that DOES....if the PPM would be the same. I'm not sure what it would be.
I wonder if a Dakota Digital SGI-5 speedometer converter box could be used to convert an ABS sensor signal to "MPH"....interesting. The Dakota Digital DSL2 also looks promising....
Old Apr 18, 2012 | 03:47 PM
02anti_vnm's Avatar
subscribed need to figure this out aswell since i will be ordering one of these controllers soon
Old Apr 18, 2012 | 03:56 PM
Tiago's Avatar
that does not work on EB2, but it could work with AMS1000.
Old Apr 18, 2012 | 04:00 PM
salemetro's Avatar
But if I used a Dakota DSL2, and used it as a fake "rpm" signal output to the Eboost2....getting it's source signal from a front ABS sensor, I'm thinking it might. In said setup, low wheel speed would translate to "low rpm"....the faster the wheel speed, the higher the "rpm" that the Eboost2 would see. So...lower gears= lower boost. Higher gear/wheel speed= higher boost.
I'm open to second opinions here...am I thinking along the correct lines?
