Fireball Twin Turbo Third Gen Camaro Build thread
#181
Pulled the factory 10-bolt out....getting drums off that have been on for 15+ years SUCKS
WIMPY WIMPY WIMPY
HEFTY HEFTY HEFTY
I want to weld in the BMR subframe connectors before putting in the new rear.
WIMPY WIMPY WIMPY
HEFTY HEFTY HEFTY
#187
Actually looks like a jeep one works well too....guy on TGO sells them prepped for about $60.
http://www.thirdgen.org/techboard/en...t-upgrade.html
Can also do it with new flaming river components, but its about $250 in parts.
#188
Me and the MIG welder aren't getting along to well today
wire keeps bunching up at the drive roller
Nonetheless, got the driver side Subframe connector tacked in...
BMR "outside" SFC
Cleaned area before welding in the SFC. small amount of rust on the pinch weld area. wire brushed well and sprayed 3 coats of rust converter. Would never know it sat outside in a "field" for 15 years
SFC tacked in
BMR "outside" SFC
SFC tacked in
#191
both SFCs are in. Mocked the rear up in place to get measurements for the coilover shocks. Looks like I'll have to modify the lower shock mounts to get my ride height right. AFCO 3850s will be a too short and 3870s are a bit too long. Had a spare 3870 shock from the firebird anyhow, so I'll make them work
MADMAN 4th gen torque arm...the crossmember is perfect width with the outside BMR SFCs
