4.8 JY build
Old Apr 22, 2012 | 10:18 AM
a4ls2goat's Avatar
Default 4.8 JY build
got this JY build done about a month ago.
mods as follows,
4.8 LM7.
LS9 headgaskets.
LS2 cam.
LS2 oil pump/chain.
Lunati dual springs.
LS1 heads.
2 bar map
walbro pump
Cobra blue giants injectors
Coolingmist meth kit.
GT45 turbo.
I put about 100miles on it and it has ran perfect.
till yesterday, i was on the freeway and as soon as i got off it started running like ****. It felt as it was misfiring, and the wideband was showing lean.
I was able to limp it home. Now it wont start, you have to give it gas to keep it at idle but still dies after a couple of seconds.
Fuel pressure is solid at 60psi, never drops while cranking
spark plugs look good.
so the wideband showing full lean has me at a loss.
any help?
Old Apr 22, 2012 | 02:16 PM
JAX04's Avatar
what kind of car? the GTO?
Anyway, what was the car tuned with? Any codes being thrown? Still have o2 sensors?
Old Apr 22, 2012 | 02:33 PM
HydroStream6's Avatar
Boost/vacuum leak.
4.8 is not an LM7 btw
Old Apr 22, 2012 | 04:31 PM
a4ls2goat's Avatar
I changed the injectors now it starts. But running rough.
It doesn't have any vaccum.
Also. Theirs a lot of pressure coming out of the valve covers. When I take off the oil cap the idle goes up. When I have to crank it a lot it shoots the oil dipstick out.
I'm running a vented catch can pulling from each valve cover.
Any ideas??
Old Apr 22, 2012 | 05:11 PM
Chicago TDP's Avatar
Sounds like you blew it....
Old Apr 22, 2012 | 05:14 PM
a4ls2goat's Avatar
Funny thing I never even got on this motor. Not even 1psi. Lol
Old Apr 23, 2012 | 10:57 AM
slow67's Avatar
Gingervitis Addict
Do a compression check to find out which hole is dead.
Old Apr 26, 2012 | 08:00 PM
01M6TA's Avatar
any update? did you ever have it tuned?
