Junkyard engine guys
Old May 19, 2012 | 03:07 PM
  #61
94'BLKBRD's Avatar
4.8's have flat top pistons and 5.3's have dished pistons
Looks like you have a 4.8 alexcoreas
Old May 19, 2012 | 03:08 PM
  #62
94'BLKBRD's Avatar
5.3 pistons
http://www.google.com/search?tbm=isc...20&bih=399#i=0
Old May 19, 2012 | 05:09 PM
  #63
a4ls2goat's Avatar
The 5.3 l33 aluminum motors have flat top pistons same pistons as the 4.8.
The cast 5.3 lm7 have dish pistons
The lm4 4.8 have flat top pistons.
Old May 19, 2012 | 05:41 PM
  #64
JAX04's Avatar
Pretty sure the LM4 is a 5.3...
Old May 19, 2012 | 07:22 PM
  #65
a4ls2goat's Avatar
5.3 * lm7
Old May 19, 2012 | 07:26 PM
  #66
JAX04's Avatar
Originally Posted by a4ls2goat
5.3 * lm7
4.8 * lm4
LM7- Iron 5.3
LM4- aluminum 5.3 (2003-2004)
L33- aluminum 5.3 (2005---)
2004 aluminum 5.3 in my mustang is an lm4
Old May 19, 2012 | 07:35 PM
  #67
alexcoreas's Avatar
Thumbs up
LM7- Iron 5.3
Thanks for clearing that up, I was searching and I'm pretty sure I have a 5.3 couldn't find a single avalanche that came with a 4.8
Old May 19, 2012 | 07:50 PM
  #68
a4ls2goat's Avatar
Cast iron blocks 4.8/5.3 with flat top pistons are 4.8s. But ok.
Old May 19, 2012 | 07:53 PM
  #69
a4ls2goat's Avatar
Let's make it simple. What casting number does the crank have?
Old May 19, 2012 | 07:58 PM
  #70
JAX04's Avatar
First of all, i was commenting your post, you were posting incorrect data their. LM4 is ALUMINUM 5.3. period.
I was in no way commenting on his engine. Then you decided to try and tell me i was wrong again, so i gave the years of production and their codes.
I was NOT commenting on his engine, mearly your post about lm4 being 4.8 litre
Old May 19, 2012 | 08:11 PM
  #71
a4ls2goat's Avatar
no need to get all pissy about it.
sorry for the wrong INFO.
Old Jun 14, 2012 | 11:10 AM
  #72
TAHOE5.3's Avatar
What is more preferable alum 5.3 or cast 5.3?
Old Jun 14, 2012 | 11:28 AM
  #73
BMF_Racing's Avatar
Thumbs up
FWIW,
we have had lots of these, 2-4.8s / 19-5.3s / 3-6.0s (all truck engine) ranging from 27k miles to 289k and all ran just fine in the 500whp to 700whp all stock internals (with ring gap and rod bolts only). I've paid from $200 to $350 for the smaller two and $700 to $1000 for 6.0L totally complete. All engines still had the cross hatching hone marks and bearing locked great. hell we even re-use the stock rings and bearings.
Only problems we have had was folding the rods into an "S". That only seems to happen when really stepping on it. See pics. That motor was drove 30 mile home, two new/old rods from a donor slapped back in and still running today full boost. God I love these engines, SBC never again.
Attached Thumbnails Junkyard engine guys-turbo-53-rod.jpg   Junkyard engine guys-turbo-53-rod-2-.jpg
Old Jun 14, 2012 | 11:45 AM
  #74
slow67's Avatar
Gingervitis Addict
That shouldn't be a problem at that power level with the newer style cracked cap rods (they also have floating pins).
Old Jun 14, 2012 | 12:39 PM
  #75
denmah's Avatar
Moderator
broke this piston and the rod is a little wavy 22lbs of boost and 15deg of timing pumpgas meth
Old Oct 10, 2012 | 11:13 AM
  #76
Forcefed86's Avatar
Any difference between the dished pistons with the cross cast into the top and those that don't have the cross? My junk 5.3 had 2 damaged pistons. Looking to replace them cheap. Found a nice piston/rod set with the cross casting on the top that I'd like to use. Any problems? Assuming these are just newer castings maybe? Are they the same dish CC etc?
Old Oct 10, 2012 | 11:25 AM
  #77
Black98s10's Avatar
I paid $350 for my 5.3L with 140k
Old Oct 10, 2012 | 11:36 AM
  #78
silver_82's Avatar
paid $175 for my 05 iron 5.3 with 24k on the clock. It didnt come with front accesories, intake or coils but I didnt care cause I didnt plan on using them.
so far so good, and Ive been beating on it like Chris Brown
Old Oct 10, 2012 | 12:33 PM
  #79
ibex37's Avatar
Originally Posted by 2nd Gen Fl 'bird
The after market parts manufacturers have got to hate threads like this. It seems the less you give a damn, the better off things work out. LOL
ain't that the truth!!
Old Oct 10, 2012 | 12:53 PM
  #80
mightybird's Avatar
Whats with these guys on ebay selling 5.3's for 2000 bucks lol
