One Guy's Garage 71 Nova TT 5.3, The Quest for 7's.
Old 02-08-2013, 06:57 PM
  #121
LS1NOVA's Avatar
717w at 17psi on a Dynojet converter unlocked 12to1 AFR. It better do 900w this year!
Old 02-08-2013, 08:27 PM
  #122
94 slow's Avatar
900? Are you going to push more boost, or are you installing a new turbo?
Old 02-08-2013, 09:13 PM
  #123
LS1NOVA's Avatar
Precision 88, ported heads, new cam, LS2 intake, 90mm tb, 25psi or wherever it stops making power.
Old 02-08-2013, 10:10 PM
  #124
typhoon1015's Avatar
i want to see a H beam through the block this year! All in the name of R & D, lol
Old 02-09-2013, 02:20 AM
  #125
2002camaroSS's Avatar
Should be fun to watch .
Old 02-09-2013, 05:46 AM
  #126
LS1NOVA's Avatar
Oh come on, dont you have faith in China metallurgy!
Old 02-09-2013, 08:29 AM
  #127
67Firebird455's Avatar
Pics! Pics! I'm going T6 on my setup. These things take up quite the footprint.
Old 02-09-2013, 08:30 AM
  #128
LS1NOVA's Avatar
It wont be back together until April.
Old 02-09-2013, 08:36 AM
  #129
Let me ask you this... what prompted the change?
Old 02-09-2013, 08:50 AM
  #130
9sectruck's Avatar
my lil 5.3 was loving the pt88, damn nice turbo,no hp #, here at a local raceway cars traping in the low 140smph on 16-18psi
Old 02-09-2013, 09:12 AM
  #131
LS1NOVA's Avatar
Really want to take the car to the next level. Thought about staying with the 76 and doing the engine mods and trying it out but Im feeling the turbine is getting on the small side if I plan on taking it to the max. Lots of SBF guys making it happen with that turbo but I have this PT88 laying here and the 84mm turbine is better suited. Still small .96 T4 AR but should make it spool well with an auto. Since I got it in the 9's last year, Id like to shoot for 8's this year if it stays together. Needs some safety updates as well though.
FWIW, I say 900 but Id really like to have a 1000rwhp 5.3. I know its just dyno numbers but I want it.
Old 02-18-2013, 06:10 AM
  #132
BanditDave's Avatar
You still running it with the trunk fuel cell and twin pumps under the trunk? Also, tranny cooler back by the trunk still? You've had a lot of drive time on this thing so I wanted to see if you had any issues?
Still looks awesome man!
Dave
Old 02-19-2013, 08:43 PM
  #133
LS1NOVA's Avatar
Yes, still the same except the Walbro 255's have been replaced by Bosch 044's. Trans cooler works great under there.
Old 02-19-2013, 10:32 PM
  #134
94 slow's Avatar
Nate,
Do you have any pics of where you mounted the trans cooler? Also, do you have a temp gauge to monitor the heat of the trans?
Old 02-19-2013, 11:06 PM
  #135
a4ls2goat's Avatar
How much boost were you running when you trapped 139mph?
Old 02-20-2013, 05:02 AM
  #136
BanditDave's Avatar
Originally Posted by 94 slow
Nate,
Do a search under the threads he started. Look for his original 6.0 build. It shows up pretty early in the thread.
If not then you can definitely find it on Pro-Touring.com.
Dave
Old 02-20-2013, 05:34 AM
  #137
LS1NOVA's Avatar
I have a good pic but photobucket has been slow lately. Its flat under the trunk floor with about 1" between the floor and cooler. Has a fan and a thermostat on it. I dont have a temp gauge but the thermostat kicks the fan on at 160 degrees and I dont hear that kick on too often.
139 runs were at 17psi with it being a little lazy out of the hole on the footbrake. I flip a toggle half track to 23psi. It has run 141 before.
Old 02-20-2013, 08:18 AM
  #138
a4ls2goat's Avatar
Maybe I missed it, but what race weight is this at?
Old 02-20-2013, 12:17 PM
  #139
LS1NOVA's Avatar
3540 with me in it.
Old 02-20-2013, 12:55 PM
  #140
I hear that man, beautiful car, and if you've got the know how, time and money then by all means, make it happen! Can't wait to see what the 88 will do in that thing! I opted for the S475, T6, 1.32 96mm turbine, if I need bigger, I'll go to the 80. I was also concerned with a small turbine on a 6.0. Just about ready to fire mine, got the engine primed up, just finishing up some wiring (replaced the whole harness for the entire car) and will get this thing going!
Quick Reply: One Guy's Garage 71 Nova TT 5.3, The Quest for 7's.
