Engine Damage at 16PSI
#42
Detonation does that, and/or lean mixtures which can lead to detonation. Then the tip of the plug gets chewed up down the side of a piston causing more damage
The wear on the skirts isnt that uncommon, especially if it's a stroker. Have the bottoms of the bores been chamfered properly ?, what sort of bore clearance are you running on the pistons ?
My last 402 with Wisecos had a huge 7 thou clearance for some reason. The skirts were visibly polished like that at the bottom. Not ideal, but dont see it as a major problem either. But being so loose in the bore, ring seal wasnt great either.
Does look like a simple tuning issue though.
A few problems going on here. First that is a TON of wear on a COATED piston skirt. There is definately a piston to wall clearance issue going on, or the motor was overheated bad.
91 octane, 16 psi, and 18 degrees is not a good combination. That car should have been tuned with 10.5-11.0 afr on that kind of pumpgas with less timing.
Providing the motor is done right, it is ALL in the tune.
A build motor will only last .5 seconds longer than a stocker if the tune is wrong.
