Forged 347/TC76/T56 Build Thread
Old Sep 20, 2012 | 09:05 PM
  #41
ren987's Avatar
yes for me it is called lack of funds the car looks great so far what are your et goals?
Old Sep 21, 2012 | 05:46 AM
  #42
White.Lightning's Avatar
I love me some build thread. Looks great. In for more.
Old Sep 26, 2012 | 09:53 PM
  #43
Tally TransAm's Avatar
et goal is 9.x, id like to see 9.7's but ill be happy with 9.anything
heres how is sits now
fired it up last week and had a couple issues but most importantly a noticeable lifter tick, hence my angry post.
measured lifter preload and I was at .113 with 7.400 pushrods which is more than i wanted. i think/hope the tick was a result of too much preload combined with 15w50 break-in oil not letting the lifters pump up.
installed a set of 7.350's today and restarted and the tick is still there but noticeably less pronounced, sounds more like a noisier than average valvetrain. more importantly it goes away as you come off idle which it didnt before. still has me a little concerned
vid from tonight (still on the old tune)
[youtube]GUstcbVXrGQ[/youtube]
any opinions on valvetrain noise?
Old Sep 26, 2012 | 10:33 PM
  #44
ren987's Avatar
Sounds like a dead lifter to me, just a guess though. It sounds distinctly like it is only one lifter. you should be able to get a stethoscope or a screwdriver to listen in and find out which one is your problem child.
Old Sep 26, 2012 | 11:34 PM
  #45
i hope not. things are brand new ls7's with exactly 0 miles and maybe 20 min of total run time. its most prominent on the front two cylinders, particularly on the pass side. no rockers are loose so i dont think its collapsed. based on the oil flow path, since 1 and 2 get oil last, im really hoping the oil weight has something to do with. i really dont feel like pulling the heads back off
Old Sep 27, 2012 | 01:14 AM
  #46
ren987's Avatar
Yea that would be really nice, I know my ls7's have done fine for me going on 3 years. Well get some thin oil in there and let us know how it does. Looking forward to some more track vids
Old Nov 2, 2012 | 10:12 PM
  #47
so i finally got the car back together.
turns out my lifter tap was a bigger issue than i thought. cyl 1 intake lifter somehow managed to frictionize itself in the bore. wasnt locked up and the cam had no scars or marking on it, but it was substantially tighter in the bore than the other 15 lifters. no idea how it happened because everything went together fine on assembly but i tore it back apart (joy), honed the bore, replaced the lifters with some comp 850's and reassembled and all seems well now
spent an hour or so on the dyno last night. tune is about 75-80%, still taking it a little easy, im kinda paranoid since this motor has been fighting me every step of the way.
happy so far, motor has 100 miles on it and theres more in the tune. gonna leave it on the spring (10#s) for a couple weeks and then put a controller on it and turn it up to 15 or so and see what happens. now i just gotta put a tag on it and go beat the **** outta it
Old Nov 3, 2012 | 12:35 AM
  #48
I8UR4RD's Avatar
awesome dude. you did everything right. must have sucked having to go back into it after that valvetrain phenomenon. I love the plate you made for the HVAC delete. Would not happen to wanna sell me one would ya since you have the template?
Old May 7, 2013 | 09:53 AM
  #49
norotor7's Avatar
Have you dynoed this with more boost yet? I'm curious how it ends up.
Old May 7, 2013 | 08:05 PM
  #50
actually yeah. did 608hp/670ftlbs if memory serves on 14#'s and 2deg less timing, still 93 octane. turbo is out of exhaust side and flatlines around 5300 rpm. ill probably change the .96 AR out for a 1.15 and see what happens
ill post a graph tomorrow, have them on the computer at work
Old May 8, 2013 | 09:43 AM
  #51
Ryans99ls1's Avatar
glad to see you got bugs sorted out Tally. Pick up a Precision or Tnetics 7675 and dont look back! You know you want to..
Old May 8, 2013 | 11:52 AM
  #52
bttlfed98gt's Avatar
Any pictures of the alternator mounting?
I've never seen anyone use the stock bracket like that.
Old May 8, 2013 | 12:19 PM
  #53
heres the 14# graph and an overlay. cheapy hallman boost controller drops about 1-1.5#'s from peak to redline
Id love to swap to a bigger turbo, but my compressor housing is less than 1/4" away from the radiator and I dont particularly feel like taking the car apart right now. Did 136 mph last time out, hoping for 138-139 with the new turbine housing
Old May 8, 2013 | 05:11 PM
  #54
Ryans99ls1's Avatar
My Hallman does the same thing. When i swapped to my Precision, the turbine housing was exactly the same and the compressor side was maybe 1/4" bigger all around. It doesnt appear to have gotten any close to the radiator either. I have the compressor exit facing straight down and thats where the tightest fit (right by the alternator idler pulley) was because of the 3" exit. Idk how you have yours clocked but if its the same i bet itll drop right in, didnt even take the radiator or upper radiator hose out for the swap.
Thats really great MPH though, were those numbers on a mustang dyno? Im hoping for 135+ this year
Old May 9, 2013 | 03:05 AM
  #55
95bowtie's Avatar
The tc7675 or 7875 should drop right on without any modification. The compressor housing is only slightly beefier than the 7668 hurricane series.
Outlet on the 7675 is same at 2.5 inchs
Old Jan 4, 2014 | 06:50 PM
  #56
DEFYANT's Avatar
Any updates Tally? Ya still alive?
Old Jan 8, 2014 | 05:14 PM
  #57
DTB_LS1's Avatar
Nice build! This might be a newbie question, but why an iron block? Are they that much stronger or cheaper?
Old Jan 9, 2014 | 08:29 AM
  #58
1CAMWNDR's Avatar
Yes and yes. He stated he got the whole shortblock out of a truck for FREE.
Old Jan 9, 2014 | 06:06 PM
  #59
still kicking, car is running fine. no issues other than traction due to this cold weather. still need to get off my *** and swap the turbine housing. really interested to see what itll do when its not choked up
like mike said, yes and yes. got the stock shortblock outta an 01 silverado for free. plus it left me with my factory shortblock as a spare for a swap future project
