turbo suggestions
Old Jun 11, 2012 | 02:23 PM
jsacra's Avatar
Default turbo suggestions
would like your guys input on a suggestion for a turbo/bov/wastegate/injectors
car: 1989 iroc-z camaro
engine: stock ls3
trans: t56
i will probably be running ls1 or truck manifolds with both sides of the exhaust routed into the turbo.
ive also consider the turbonetics t series 76mm with ceramic ball bearing
and a procharger bov (like stangkilr love that set-up)
main a street car so not to sure on the turbo a/r size
thanks guys
Old Jun 13, 2012 | 12:34 AM
jsacra's Avatar
Considering a turbonetics. T76 76mm ceramic ball bearing with a .96 a/r
any suggestions? Also or the hot/cold 3in piping?
Old Jun 13, 2012 | 01:00 AM
HRHohio's Avatar
On3 Performance 76mm Ball Bearing (.96 AR front mounted, .81 AR rear mount).
Old Jun 13, 2012 | 01:44 AM
itsslow98's Avatar
I'd reccommend staying away from on3 in general. Id go turbonetics, precision, garrett, borg warner in no particular order.
Old Jun 13, 2012 | 03:31 AM
typhoon1015's Avatar
precision 7675, better exhuast wheel/size than turbonetics, can get .96. 1.15 and 1.25 ar exhuast housings, .96 or 1.15 would work best. it is a T4 as well.
Old Jun 13, 2012 | 04:13 AM
itsslow98's Avatar
Thats what Ill be upgrading to when the time comes, although Precisions quality has dropped considerably from a lot of the reading i've done lately. Im running a Turbonetics F1 Turbine Hurricane Series currently.
Old Jun 13, 2012 | 09:24 AM
skifreek's Avatar
why? i was considering going that route... is the turbo that much shittier quality?
Old Jun 13, 2012 | 09:31 AM
HRHohio's Avatar
Any particular reasons to stay away from On3, in general? Just curious...
My opinion only... , the On3 76mm BB will provide all your motor can handle...for a stock LS3 setup. Also, it's nice and compact and has had good reviews by those who have actually used them, myself included. It's a good unit to get you into the game at a fraction of the cost of the others listed above. Not saying that they aren't good units, just saying that you can get a good unit at 1/3 of the cost. Again... my opinion only...
OP... Front Mount setup I take it? Oh, and I wish you the best in whatever you do end up goint with.
Old Jun 13, 2012 | 09:35 AM
HRHohio's Avatar
I'm running a rear mount On3 Ball Bearing 76mm with .81 AR. I've had no issues with the turbo unit at all. There's another thread just about On3 Turbos. Everyone who's run them likes them, as far as I can tell. Everyone who sells the higher dollar units seems to knock them...in general. I haven't heard anyone who actually owns one complain about them.
Old Jun 13, 2012 | 09:46 AM
skifreek's Avatar
does it run out of steam with a forged top end, ls2 heads, and cam setup?
Old Jun 14, 2012 | 12:29 AM
HRHohio's Avatar
Unfortunately, I can't say from personal experience on that one. Hopefully some day I'll be able to.
For my setup, at 10 lbs boost, with LS9 Cam and stock heads/bottom, it was pulling hard all the way to 6000 rpm.
I believe the specs are similar to the Turbonetics TC76, so I would imagine similar performance.
Maybe someone else who's run one and is forged can chime in.
Also... here's a nice long, in depth thread that discusses the On3 Turbos. Good read.
https://ls1tech.com/forums/forced-in...on3-turbo.html
Hope it helps to answer some of your questions.
Old Oct 18, 2012 | 04:20 PM
lsxtreme17268's Avatar
Older post but hopefully i can still get a answer( hey at least i used search lol)
Im looking at getting a on3 turbo like yours for a rear mount setup
here are the specs on ebay
Cold Side:
Compressor Wheel 76mm
.80 a/r
4” Inlet and 2.5” Compressor Outlet
Inducer- 76.71mm
Exducer- 102.36mm
Exhaust Side:
Exhaust Housing T-4 Flange
.96 ar Exhaust Housing (.68, .81, 1.0 divided, 1.15 divided $30 charge for swapping housings)
3.0" Vband outlet
Inducer- 74.5mm
Exducer- 65mm
So are you saying you ordered the .81 ar exhaust housing ?
