Meth failure?
Old Jun 25, 2012 | 08:40 AM
mconway68w's Avatar
Default Meth failure?
I'm just wandering. Who all has or know somebody that has had a catastrophic failure due to their methanol system failing?
Old Jun 25, 2012 | 09:20 AM
dschmittie1's Avatar
IF you tune your car properly and you are not using the METH as a crutch for an innsufficent fuel system then a METH failure isn't going to make you loose a motor.
Old Jun 25, 2012 | 10:49 AM
9sectruck's Avatar
no one that I know of here local... but the car is not tuned for the meth injection to keep the car alive just to kool the air charge.
my personal car would move .5afr if I ran out of meth. my car is tuned 11.3-11.6 at wot on the meth
Old Jun 25, 2012 | 10:51 AM
mconway68w's Avatar
I agree. I'm just wandering who's actually had it bite em in the ***. Or just whos had any kind of meth failure. I'm using snow meth and pretty comfortable with the setup and tune.
Old Jun 25, 2012 | 11:12 AM
ICRAZY6's Avatar
My buddy blew his motor due to meth. He was told that meth was the way to go when he had his procharger put on. The tune was meth dependent and the pump went out on it. Kaboom!
Old Jun 25, 2012 | 03:33 PM
I know MRBIG has his corvett set up correctly using Meth and he had a failure and didn't hurt the motor. e
Old Jun 25, 2012 | 04:27 PM
357i's Avatar
I had an issue with mine(self inflicted) but Frost tuned it right, and I had no problem. There is a lot to be said about having it tuned properly with the meth
Old Jun 25, 2012 | 09:09 PM
got-a-ls1's Avatar
yep if you are using meth as a direct fuel source or as a crutch against detonation running stupid timing your asking for trouble... i take a chance at the track and up my timing but i have a very aggressive IAT table to pull timing for high IAT's. i back the timing down on the street so the meth doesnt really matter if it fails.
Old Jun 25, 2012 | 09:16 PM
pimpjames's Avatar
I had a failure from my Snow Kit. For some reason the pump stuck open and once it tried to start the next day.... Hyrdo lock....
Old Jun 25, 2012 | 09:35 PM
Wicked69's Avatar
I use AIS and no failures. Of course I tuned to NOT use it and then added it. I kept adding more alcohol to the water mixture until the car ran better. I know it is kind of backwards but the car has run a best of 118mph in the 1/8th and it is a daily driven 4000lb chevelle. I also use E85 so even if the meth fails the E85 gives you a ton more room for error.
Old Jun 25, 2012 | 10:59 PM
I8UR4RD's Avatar
i would not advise tuning it to be dependant on the meth. use it for the cooling benefit only if possible. i mean you can add a degree or two, but just pretend its going to break on day. no pump lasts forever. might be today might be 10 years. better safe than sorry.
Old Jun 26, 2012 | 10:24 AM
Slowhawk's Avatar
LS1Tech Sponsor
I've tuned about 30 cars methe dependant. No failures to date. We use alky control kit's only from our long experience with them. Use to work at a Ford shop that only used Snow kits. Atleast once a week they had a failure with those kits.Luckilly they only used crap windsheild washer fluid.
