Kuwaiti 370ci TC76 l92 max safe power
A bigger AR exhuast housing would help.
I think 17 psi, with a smaller turbo is just too much on straight pump gas,
back pressure and intake temps would be very high, leading to a high chance of detonation.
I personally would add a meth kit for anything on pump gas pushing 15 plus psi boost.
Again fuel was plenty all through dyno tuning never leaned out...
You can only do so much on pump gas. Driving on the street is much different than the dyno.
I would get some race gas and methanol injection. Tune it on the street and watch knock. See what it will take as far as boost and timing.
Low compression+(at least 93 octane) pump gas , should be good for 700-800whp on a good tune and good engine i think
The other time was just two weeks ago, It was a cold night & it ran a little too lean plus I ran out of methanol. It went boom. **** happens on pump gas if you push it hard.
My C.r. Was at 9.5-9.7:1 with -11 pistons and 67cc chambers, and i just got confirmation from a specialised lab on the pump gas here,it's 98 octane.
Ever wonder why even forged motors pop cylinder #7? Surprised no one has said it, but this engine needs REAR STEAM PORTS! Everything thing else looked fine about your setup. Meth/water may have prevented this failure as well.
The other thing is the power handling of different blocks. IMHO, you are pushing an LS1 block beyond it's limit. LS2/LS3 blocks can handle more than LS1, then iron block can handle even more. It's like 650 crank hp for LS1, 950 for LS2/3, and 1150 for LQ9. I'm running a LQ9 block with meth for three years with no issues.
Here's a copy of an e-mail I sent to a friend of mine about steam ports:
https://ls1tech.com/forums/generatio...-hp-setup.html
I used an LS6 front crossover pipe on the rear, bent the outlet at a little more angle and ran a hose along the side of the intake up to the front and joined it with the otlet of the other crossover with a brass T fitting...Working great...
GM Part Name: Engine air bleed
12602544
Anyways, 12604711 (two port truck) and 12602544 (two port LS1) are readily available at GM parts stores, Summit, eBay, etc. If you want a 4 to 1, you gotta go used.
If you need the little oblong washer/o-ring setups, they are PN 12551933 which are about $6 each.
(Some of these part #s may not be available)
LS6 part: 12568478
LS1 part: GM part # 12602544
f(ls1) pipe,eng cool air bl(incls 539-542)
(if prior to 2002 vehicle, must us 2 caps p/n 12602540)
4 into 1 tube = GM part# 12557538 Y-body '97-'99 LS1
bolts = GM part# 11514008 (without stud-head)
http://www.kurturbanperformance.com/...or-system.html
http://www.krcpower.com/catalog_i112...l?catId=366482
http://s41657.storefront-solutions.c...l.aspx?ID=3289
https://ls1tech.com/forums/forced-in...4-why-7-a.html
https://ls1tech.com/forums/forced-in...on-system.html
https://ls1tech.com/forums/forced-in...cs-inside.html
The reason gm did it is because they didn't build the engine with 650hp. At 350 hp from the factory those steam vents don't do anything. I melted 2 forged motors on cly 7 not running steam vents on 93 octane at the track.
https://ls1tech.com/forums/conversio...-adapters.html
12602544
LS6 part: 12568478
12602544
LS6 part: 12568478
12602544
LS6 part: 12568478
Thanks again
#32
I've read about this but never gave it much thought, thanks great read, guess it was a heat issue on #7 since every other thing seems ok, my engine has been running a little hot even with an electric water pump and high flow fans, and if steam porting the heads would bring the temps down i can't say it is not worth doing.
Thanks again
Thanks again
Anyway, glad I could help and good luck with your next build.
