Critique my f1a build please
Old 07-06-2012, 10:51 AM
+badss+'s Avatar
Default Critique my f1a build please
Trying to see what you guys think of my set up so here it is
Forged 390 cr 9.5-1
Callie's h beam rods
Callie's dragonslayer crank
Diamond -15 dish pistons
1/2 in head studs
Main studs
Ls9 gasket
Comp cam 232-238 .595-.603 114+4
Ls6 intake pnp tb
80lb injectors
Mild ported 317 heads with dual vs
Trans in jakes lvl 2 4l80e fmvb with t-brake
3600 billet stall converter
Tci flexplate
Strange 3in chromoly ds
Strange S60 s trac 3.73 35 spline axles
F1A 8 rib procharger with these options
Fmic
Big red race valve
Aster bracket
Ati balancer
Not sure of pulley size but we are shooting for 15lbs of
Boost
Snow stage 2 meth kit 51/49 mix
93 octane
All new fuel system good to 1000rwhp
We are thinking 800 rwhp shifting around 6500
Is this a strong build for my goals of 800rwhp
I know heads and intake are
Major
Limiters but feel there fine for 800.
Old 07-06-2012, 02:06 PM
blue00ZZleeper's Avatar
Sounds pretty decent man. Don't forget tune, gauges and other applicable stuff. Looks pretty solid though....should make over 800 pretty easy, might need a touch more boost though.
Old 07-06-2012, 02:36 PM
+badss+'s Avatar
Yeah it's getting all gauges and a sd tune from Lashway so tune should be spot on.
Old 07-06-2012, 07:30 PM
LS1RedZ's Avatar
Hell yeah that's a top notch setup man. I'd put the 3.7 pulley on and let her eat!!
Old 07-06-2012, 09:36 PM
+badss+'s Avatar
Not sure what pulley they are going to try a few to see what motor likes. Next year I
Might do better heads and a better intake set up
See if I can crack 1k thru auto
To the wheels. But was just wondering what people think of the way I put this set up together if it'll run like a beast or if there's something I've missed.
Old 07-06-2012, 09:38 PM
+badss+'s Avatar
Not sure how to
Figure out what pulley does what I think crank is the 7.65 pulley
So I would assume 4.0 or 3.7 for 15lbs plus can someone tell me what psi I will
Make with a 3.7 and 3.4 pulley
Old 07-06-2012, 09:41 PM
WheelsUp84z's Avatar
if it were me I'd just get some bigger injectors to start with. some FIC 120's or some low Z 160 with injector driver.
Old 07-06-2012, 10:23 PM
+badss+'s Avatar
what are 80lbs good til? these were recommended by lashway and a few others.
Old 07-06-2012, 10:30 PM
josepy121380's Avatar
I still think you should trade me my F1c for your F1a
Old 07-06-2012, 11:08 PM
+badss+'s Avatar
No way I'm getting the newness first haha, then I'll decide if i need something else. who knows maybe ill step up to lsx block and a f2 and hit up x275 class. but thats getting ahead of myself.
Old 07-06-2012, 11:09 PM
+badss+'s Avatar
and besides my car is just about done waiting on new ati balancer because the wrong one got sent.
Old 07-06-2012, 11:31 PM
I8UR4RD's Avatar
if i were being critical, id say you have a badass setup first of all.
for your goals however
the level 2 jakes should be turned on up to at least a level 4-5
the 317's although they flow like crazy, do have a thin deck. and with your setup and getting up to 900-1000+ I would just consider a thicker deck some good insurance.
as far as the injectors. i am going with bosch 127lb's from FIC or through lonnie. im going to go ahead and do the fast 102 since its the same price as the 92mm. less restrcition the better. i dont want to deal with all the cutting and banging for the vic jr or the holley. other than that...shed some weight off of it. make a 100lb goal.
Old 07-07-2012, 01:02 AM
+badss+'s Avatar
Thanks i8 I will go bigger inj. When I can get my aftermarket heads probably next year.
I do plan on having the trans sent back for billet hard parts I think it should live at my power lvl til I can get it back to them.
As for the intake I'm doing the carb intake probably with a elbow and 102 tb most likely when I do the heads for now ls6 should be fine.
Old 07-07-2012, 01:37 PM
stngtamr29's Avatar
Originally Posted by +badss+
Not sure how to
My and your engine specs are very similar and im running 3.7 upper 7.65 lower
3.7 will max out the F1a 3.4 will over spin it and why are you going with such low compression Im running 10.7 and have had no problems at all. The only time my car has been on the dyno we were leaking about 2 to 3lbs off boost through my wastegate and only making 16.5 Now we have added co2 to the w/g and we can make around 19 psi so we should be over a 1000rwhp with this combo also I would run a bigger injector Im running 120's. jeff
Old 07-07-2012, 02:36 PM
ls2 bait's Avatar
Id go with an aftermarket head for the thicker deck such as the as cast tfs. And the cam is meh imo. I think you could get more aggressive.
Old 07-08-2012, 10:08 AM
LS1RedZ's Avatar
Yeah some TFS235s would be a GOOD addition to that setup and it would be ready for some serious power now and later on if u do go F2. I think I'm gona sell my heads and pick up a set of them myself.
Old 07-08-2012, 11:04 AM
+badss+'s Avatar
What cam would work better? this is the cam AES recommended for my set up but i had them make it on a 114+4 instead of a 113.
as for heads i do plan on changing them for some AFR heads just didn't have enough money to go fi and everything.
Old 07-08-2012, 08:37 PM
ls2 bait's Avatar
Im sure it will work just fine. Im just one to go big or go home haha.
Old 07-08-2012, 08:54 PM
I8UR4RD's Avatar
i imagine we went with lower compression, because longevity comes with it. OH snap badss I went 9:6:1! look out! I went with that CR because there will be times when I cannot run e85 and I dont want to risk that "one bad tank of gas" or etc....its just insurance. stngmatr does drive his every day it doesnt rain though. If either of us decide to take it up higher later on that will be easy enough.
Old 07-09-2012, 12:48 AM
+badss+'s Avatar
Yeah just did it for room to go since running 93/meho but might go up higher when I get better heads.
Quick Reply: Critique my f1a build please
