how much boost can you build off the foot brake? VID inside
how much boost can you guys build off the foot brake?
on my 5.3 with a ls9 cam and a GT45 i can build almost 5psi with a 3600 stall
My drag radials could only hold 11psi. With slicks now I can more but havnt checked how much. 370 PT76gts TU1 cam and a BTE 3600-3800ish stall My powerglide and a 3.50 gear rear helps. If you have a lower first gear or lower gears in the rear it will be harder to hold and build boost.
