Turbo Advice. Looking to upgrade from PT88 *COMP TURBO RESULTS*
Specs on the motor:
383 LS1
WCCH CNC'd 317's
10.8:1 compression
236 232 .605 .596 115 lsa
Edelbrock Pro Flo
160lbs Injectors E85
Truck Manifold kit 2.5" crossover, T4 Flange, 4" V-band Down Pipe. A2A intercooler with 3" cold side.
Wanting to stay T4 flanged for now.
TH400
Neal Chance converter
8.8" rear with 3.27 gears
28" drag radials
Have been running a PT88 .96 A/R on an undivided T4 housing. The car made 936rwhp on 19lbs of boost, but would make 22lbs on the street. Went 9.20@155mph. Well the PT88 took a **** within 2000 miles of a rebuild (see pic) it looks like the compressor wheel touched the housing. Precision wants $1500 to rebuild it and a brand new PT88 is $1600.
Looking to upgrade to something that is still a T4 flange. Wondering what you guys think. Want to stay away from precision.
Thanks for your help.
-Sean
383 LS1
WCCH CNC'd 317's
10.8:1 compression
Edelbrock Pro Flo
TH400
28" drag radials
-Sean
Has anyone else had a PT88 or any Precision fail like this. I know people were having drainage issues causing them to fail but I have never seen this out of a high end turbo. Especially a freshly rebuilt one. Do you think it maybe could be the way it was re assembled?
i had my pt88 take a crap on me after i bought it freshly rebuilt on another board. i ended up having Reed at the old super natural turbo rebuild it for me. it cost almost as much as a new one but i knew it would be done right without issues. car has been almost 154mph with it on 19psi. took a blast in it last night at 24psi and the turbo is still going strong for now..24psi was a little much for street pulls though lol. if this turbo ever went again i would like to try the gt91 i think it is?
its from forced inductions, it fits into a pt88 exhaust housing
i ran a 8.49 at 162 and change at 26# boost thru a stock intake and throttle body on a 364ci. at 3750# weight
the specs i didnt asked for, told em i needed it to package where my 88mm was and they delivered.
have to ask them
relevant threds w/ pics:
https://ls1tech.com/forums/forced-in...ally-home.html
https://ls1tech.com/forums/forced-in...ick-treat.html
have to ask them
Specs on the motor:
383 LS1
WCCH CNC'd 317's
10.8:1 compression
Edelbrock Pro Flo
TH400
28" drag radials
-Sean
383 LS1
WCCH CNC'd 317's
10.8:1 compression
Edelbrock Pro Flo
TH400
28" drag radials
-Sean
