Supercharger..
Old Jul 22, 2012 | 05:13 PM
Justin Gibbons's Avatar
Default Supercharger..
Hey don't know a whole lot about superchargers, maybe I can get some feed back here;
1) I have my ls1 stroked to a 383, forged internals, H/C/I, how much boost could the engine take?
2) Right now my compression ratio is about 11.3 to 1, 64cc heads, pistons are -3(I think), so whats the best way to get the compression down, and what compression ratio should I shoot for?
3) looking for 600-700whp, if the block can take it, what supercharger should I use?
thanks
Old Jul 22, 2012 | 05:51 PM
conan's Avatar
Find your self some 317 heads, or go with an aftermarket head with a 72cc combustion chamber to drop the compression I would try to get it down to 9.5-1. D1 procharger and upgrade the fuel system. What are the specs of your cam ?
Old Jul 22, 2012 | 05:57 PM
Cam specs are 230/234, .598/612, lsa 113
Old Jul 22, 2012 | 10:18 PM
blue00ZZleeper's Avatar
X2. That's exactly what I would do. Go with a set of 317 heads, LS9 Headgaskets, ARP head studs, a new or used D1 kit with an Aster bracket, Basic fuel system. I think that cam will work just fine as well.
Old Jul 23, 2012 | 12:04 AM
I8UR4RD's Avatar
I have a damn near new d1sc right now for sale if you are interested. PM me if you ready for some serious power.
Old Jul 23, 2012 | 06:10 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://shop.brutespeed.com/98-02-F-Body_c181.htm
I sell almost of the parts necessary to complete a used ProCharger kit for a 98-02 F Body at the above link. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jul 23, 2012 | 07:50 AM
I have a racetronics fuel pump, with hot wire kit, 42lbs injectors, what else would I need for the fuel system?
Old Jul 23, 2012 | 08:15 AM
M2W-GTO's Avatar
Bigger injectors. More pump, or a BAP.
Old Jul 23, 2012 | 10:41 AM
conan's Avatar
60# injectors, and I would just do a dual intank pump setup with a hobbs switch and be done with it.
I tried a single pump with a hot wire kit... Fail- 25psi @ 5,200 rpm's.
Kenne bell Boost-A-pump on a single pump... Fail- 40psi @5,400 rpm's.
Lonnies double pumper... 60psi @ 7,000 rpm's
Old Jul 23, 2012 | 12:33 PM
I8UR4RD's Avatar
yeah I am referring all the guys to you for the parts needed to complete the kit. the only thing on cost i was not sure of was the intercooler and charge piping itself.
to the OP you def will not make it on those injectors. sell em and get some 60's or 80's
Old Jul 23, 2012 | 02:27 PM
Go with a set of 60lb injectors and twin walbro GS-340's. I run mine on the whole time and I'm actually still on the stock supply line and use the vent line as my return....a bandaid for sure but it got me to 830rwhp lol.
Old Jul 25, 2012 | 07:48 AM
Not to change the topic, but what are you FI guys doing to beef up your trans(M6)?
