holset hx52/hx55
I have a friend with a LS2 GTO with an HX55, it spools pretty quick. He has the billet titanium comp wheel version, which is pretty nifty.
The turbo's frame is pretty huge compared to the size of the wheels. What are the measurements on yours? They seem to vary pretty considerably.
The only real info I have found on using hx52s on gas engines is a few DSM guys using them to push 600ish hp at 30lbs. It should work fine on a larger v8 but as of yet I haven't found anyone that has tried it. I'm planning on giving a hx52 a go on my 98 z28 but I have to get everything else in line first.
I'm using one for my 3800 build, I plan on running 16-20 lbs on it. They are great turbos to use being a journal bearing. They can be had for cheap and last forever.
The only beef I have with them is the wacked out measurements of the outlet and the inlet flange.
The outlet vband measures 3.5" id and 4.75" od....soooo, in order to overcome this, I am using a 4" id and 4.75" od flange welded to a 4"-3" reducer.
The inlet flange is a T4, yet the bolt center to center length long ways is about 1/8th-a quarter inch longer.
umm are you sure on the t5? because im not getting a T5 measurement on mine..I ordered a flange from a company that is specified as a flange just for a 52
