Turbo to small questions
What I want to know is WHY. Why is it to small? Looking for 600-700whp. But again what makes it to small?
https://ls1tech.com/forums/forced-in...6-0-hx35w.html
so something like T-70, Q-Trim .96 AR but the prices i'm seeing something like that for i'm much better off with the S475.
When you run the compressor over on the right hand side of the map, the compressor has to spin a lot more rpm in general. The is hard on the shaft and bearings so the turbo doesn't last as long. It also makes the air hotter in general so you are actually putting less oxygen in the motor and less power than you would with a bigger compressor at the same boost level.
The S472-475 with the 83mm T6 is the best bang for the buck if you plan on more than around 12psi. If space is an issue than a cast PT7675 is comparable.
you might want to do some more research.
Try an online turbo calculator....
