spec my s480 :)
Old Aug 9, 2012 | 08:09 PM
10secondZ's Avatar
Default spec my s480 :)
Gonna order a t4 s480 soon, just curious as to turbine and a/r size that would suit me best. Specs:
Forged 347ci 9.6:1
CNC'd 317's
224/228 .581/.588 115
Victor Jr with 6061 elbow 90mm
truck manis 2.5" crossover t4 flange
80lb. injectors
TH400 RMVB with PYE3600
2.73 gear
Anything else needed to know just ask I would like to know if the s475 would be better suited, or the s480. Opinions?
Old Aug 10, 2012 | 06:20 AM
turbocamaro125's Avatar
What kinda power? I would do t6
Old Aug 10, 2012 | 09:44 AM
DrTurbo's Avatar
LS1TECH Sponsor
Depends on the level of power. Also the turbine wheel will be critical. If your going to go T4. Then go with either the 87mm turbine wheel version or the 92mm LDP wheel. The 92mm LDP wheel has been making some ridiculous power lately on customers combos and spools insanely fast as well.
Old Aug 10, 2012 | 10:55 AM
SPRAYED 01's Avatar
How huge is a t4? How does it compare to a pt88? Also what it the price with the 87mm?
Old Aug 10, 2012 | 11:00 AM
DrTurbo's Avatar
LS1TECH Sponsor
The turbine housing itself is smaller then a PT88 turbine housing. The Comp cover is 9" diameter vs the PT88 is 7.5". I will PM the price to you.
Old Aug 10, 2012 | 12:24 PM
10secondZ's Avatar
Sounds like a good set up, i'll probably do the 92mm wheel, looking to hit 800rwhp through a th400 could you send me a price on the 92mm wheel t4 s480?
Old Aug 10, 2012 | 12:28 PM
DrTurbo's Avatar
LS1TECH Sponsor
PM sent
Old Aug 10, 2012 | 03:23 PM
10secondZ's Avatar
PM sent
Call you soon!
Old Aug 10, 2012 | 03:38 PM
DrTurbo's Avatar
LS1TECH Sponsor
Call you soon!
No problem.
Old Aug 10, 2012 | 07:34 PM
Sales@Tick's Avatar
92mm all the way.
