Anyone use a Magnum 80mm turbo yet?
Old 08-11-2012, 10:36 AM
tennerv8's Avatar
Default Anyone use a Magnum 80mm turbo yet?
Hey fellas, wondering if anyone has used a Magnum 80mm yet? Just looking to see what kind of power numbers guys are making with it.
Old 08-12-2012, 12:09 PM
tennerv8's Avatar
Nobody then...okay.
Old 09-10-2012, 02:50 PM
a-low's Avatar
Bump.. i too am curios about this. So far it seems demah is the only person ive found running one on 5.3.
Old 09-10-2012, 04:10 PM
tta656's Avatar
why spend on a magnum when you can get 2 or 3 Chinese turbos
Old 09-10-2012, 06:29 PM
BottleFedZ346's Avatar
I know Denmah on here just slapped his Magnum 80mm on his fairmont, he seems to like it so far!
Old 11-05-2012, 01:47 PM
o2camaross's Avatar
I just ordered the CXracing version for 1/2 the price and as far as I can tel it is the EXACT same turbo haha!!
Old 11-05-2012, 01:53 PM
Moderator
denmah's Avatar
im going to dyno soon non intercooled, and see the difference and if my intercooler was a restriciton, but truth be told as of right now it doesnt seem to make anymore power than a 260 dollar gt45...
at least in my experience.
Old 11-05-2012, 01:59 PM
Moderator
denmah's Avatar
yeah i see this
http://www.ebay.com/itm/CXRacing-GT4...ffecf6&vxp=mtr
is exactly what i have, mine just says magnum on it.
if i can make much more power without the intercooler it might have been worth it.
but honestly i wish i had just built a twin gt45 kit or something rather than drop 1100 on this thing
Old 11-05-2012, 02:18 PM
o2camaross's Avatar
Yea I pretty sure it is the same exact turbo as the Magnum, It has the same cover and turbine housing and the turbine and compressor have the exact same specs. This turbo should most definitely make more power than my 76/65 on3
Old 11-05-2012, 05:30 PM
knuts82's Avatar
Can anyone verify this are they the same.
Old 11-05-2012, 05:43 PM
NemeSS's Avatar
+1^
Old 11-05-2012, 06:44 PM
o2camaross's Avatar
read this thread and compare the magnum specs to the specs of the ebay version. And look at pics of them both. They are visually identical and the specs are also identical
http://www.yellowbullet.com/forum/sh...d.php?t=443343
Old 11-05-2012, 07:35 PM
knuts82's Avatar
I found these guys offer the same one too.
http://www.ebay.com/itm/160898874833...84.m1423.l2649
If you look close at the turbine housing they ground the numbers off
Old 11-05-2012, 08:11 PM
Moderator
denmah's Avatar
i made 697rwhp today with this turbo and stock 799/243 head and ls9 cam
i think my 5.3 has had it though, lots of blow by now.
Old 11-05-2012, 08:14 PM
ronnieforrester's Avatar
RIP- you will be missed
Old 11-05-2012, 09:03 PM
tta656's Avatar
Anyone know if these are balanced,they usually grind on the nut to balance,,these dont look to be balanced,,,
Old 11-05-2012, 09:13 PM
knuts82's Avatar
It says this in the add right under the cars in the pic. But who knows...
"High Quality Built product. Each Turbo is individually tested and computer balanced."
Old 11-05-2012, 09:30 PM
Moderator
denmah's Avatar
yeah correction i did 697rwhp with 3 dead cyls lol
Old 11-05-2012, 11:09 PM
a4ls2goat's Avatar
wow.... i might just get this sometime soon
Old 11-05-2012, 11:16 PM
Moderator
denmah's Avatar
im sure my builds are not the greatest thing to test this turbo with, rob says it flows 110lbs a minute wich shouod be able to squeeze out 1000flywheel i would think, or 800+rwhp,
and its getting there, maybe if i had ported heads, and a fast intake, and could keep a motor alive for long enough hahah
but im still learning
Quick Reply: Anyone use a Magnum 80mm turbo yet?
