Enough Room for s91??????? Stock radiator and condensor moved forward.....
#41
Not sure where you came up with that. S91 = S400-HP91
http://forcedinductions.com/productsborgwarner.htm
Compressor cover diameter is around 10.5" and the same goes for the turbine housing with the T6 flange. It's also about 10.5" from the down pipe flange to the air filter inlet.
#44
OP are you using a 96mm turbine 1.32 ar hotside unit or a different AR(1.0, 1.15, 1.45 etc.) 111mm turbine unit?
Are you thinking that the HP91 and S91 share the same turbine cover even though the exhaust side is different? I don't think that's the case(no pun intended) though?
#45
Im between the s400-91hp and the gt91 for my build plans. Both seem to be pretty good prices. Think one is 1599 and other 1699 on fi website. Both ive seen used on builds yield good results so guess probably couldnt go wrong either way.
#47
That's what i hear everyone saying. Was measuring today and if i get a smaller condenser like a 12x24 to be exact it will fit right under hood latch and then can move radiator that much more forward. May have to trim fan shroud a bit but believe i can get 11" of clearance from back of radiator to front of ps pulley. I wanna mount my turbo there in front of power steering pump. Do abs delete.
#50
Im going to be trying a very similar setup. I already have my radiator forward to fit a comp ct5 turbo. But id love to get a big bw in. there. I was thinking of getting rid of the hood latch for some pins and a smaller condensor.
#51
Found a globle brand universal 12x24 on ebay today for sixty bucks.. Have to chg ends on lines or whatever to make work
#53
Originally Posted by 93camaro_zzz
Look to Killer-Ls1 I think his screen name is, for reviews on the GT91 turbo.
Me personally I would definitely go with the S400-HP91. I would not skimp on price on the most important piece of a turbo system.
Posted from LS1Tech.com App for Android
