Cracked block @ 27psi - Time to step up
Forged LS1
1/8: 6.5 @ 111mph
made 620 on 11psi
stock suspension / 10 bolt
Racing a terminator last year
Long story short, raced a busa from a roll going to a dyno meet and when I pulled into the meet antifreeze was spewing out. Initially thought it was a head gaskets but later found a crack across number 7, after checking the data log it showed a total of 27psi, I was shooting for 11 so something went fubar with the controller. Good thing atleast was when we tore the block down nothing was messed up internally, pistons, rods, rings, everything looked normal so after talking with my builder, sam daffron, he says it was caused by the motor mounts, the block torqued so vilantly under that much boost with no motor plate causing the crack. If I had known the internals were salveagable I wouldn't have decided to go bigger but oh well, I ordered everything before we tore it down because i was sure there would be problems.
The engine will be done this weekend and we're setting it off in the car to hopefully have some tune time before lsfest next weekend.
402 ci LS2 (4.005" bore)
4" Stroke Eagle Crank
Diamond -31.9cc Dish Pistons (ceramic coated, teflon skirts)
Manley Billet Rods
Total Seal Stainless Steel Rings (ms3906-5)
Same cam - 22x/23x .61x/.62x 115+2 LSA
Block
Pistons
Mock Up
Your camaro sounds killer, and you will really like the extra cubic inches even if the compression is pretty low.
Exactly. I don't buy the motor mounts story either, not even for a second. For added insurance, iron block all the way!
i tried calling him and emailing him a few times a few months back and never heard from him and didnt know what happened.
good luck with the new build!!
Im really curious why more people dont implement this. Its not like its gonna run lean and melt **** with no fuel, or an extremely small amount of fuel going in... i see no downsides and having hit that cutoff probably 10 times at WOT on a stock motor i am not worried one bit. Ill tell ya one thing... you know it when it reaches that point on the map and instinctively lift off the gas. your talking less then half a second in most instances. Its basically like hitting the rev limiter... motor has no fuel and falls on its face. One important thing to try and remember is to have some room in your normal boost range and the cutoff as i think the VE table blends the cells.. i liked to keep the cutoff 15kpa above my peak boost.
How is it that detonation caused the crack on the outside of the block across the cylinder wall, and the inner sleeve looks fine?
