Small external size single turbo?
Can anyone recommend some turbo models to look at to suit a 6L with minimal space under the hood?
I know the GT4088 has been used, but is there anything that will flow better but not be the size of a Gt42.
The car is a stalled a4 with a cam.
Another question i have is, will the car drive different offboost to what it does now as an NA? Or do you lose power until its in boost?
I dont have the luxury of room in front of the motor where most people fit big singles so it will need to be off to one side
http://www.turboneticsinc.com/turboc...-turbochargers
As for driving, it should drive no different than it does now. It may feel more sluggish off boost, but that's only because of the larger difference in power between on and off boost.
But it will make pretty much the same low end as it did before.
)Spool shouldnt be an issue with a high stall and a turbo of this size i wouldnt have thought? The car is just a weekend warrior with a semi focus on drags but nothing crazy.
But as you also say, some modern big turbos can actually spool very well.
A lot of guys have good luck with the 88mm sized units and it would also leave you room to grow at a later date. Even then there is a huge variety of brands and different specs within that size range.
I'm sure some of the more experienced guys will chime in soon
https://ls1tech.com/forums/forced-in...rbo-build.html
I am having no luck getting in touch with drturbo on where to buy the tc7675
You'd be looking at the T76 S trim basically with a different compressor housing.
TC compressor housing = 4" in & 2.5" out.
H cover (aka GTS, HPSH) = 4" in & 3" out.
