lq4 s10 + twin 70's
#481
ground down the v band off the s475 because im not going to pay $50 for a ******* flange and clamp
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zpsa8765b75.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps352c8d8e.jpg)
finished hotside (waiting for wastegate to come so i can mount it)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps88f581cc.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zpseb44c52b.jpg)
turbo mounted
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps27e011c1.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps413859fa.jpg)
coldside complete (waiting for bov flange to weld in and mount bov)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps8b6fada3.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps74f83493.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps123c6d14.jpg)
downpipe almost finished, just need another foot of 5" pipe and wideband bung
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps6fcb5f82.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps8a9c9ee8.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps5a516820.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zpsc79d2ad1.jpg)
everything put together
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps4ed7197e.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zpsc02dabfe.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps7339e468.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps3a3488f8.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zpse400d8af.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps28a6d82c.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps20616ca3.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps2da055e8.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps75c57c09.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps7aaba564.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps0ed3b355.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zps208a794b.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880012/image_zpseff4d523.jpg)
all the pipe will be finished this upcoming weekend. entire hotside will be wrapped also. hoping to have this thing driving and doing burnouts at our local world of wheels car show at the end of march.
turbo mounted
#484
Looking good, Back in 2000 I was running a blow thru on my stang awesome part is you can run a good bit more timing and no need for intercooler. Is that a CSU or home modified carb? I ran both, however, my home modified carb was a lot nicer on the street, it was a 357 CID ford with 88mm and 750 modified carb it put down 1241 rwhp 32 lbs of boost.
we used to add add extended vent tubes with flares on the inlet allowed you to run smaller jets and the little pressure difference would increase pressure in bowl as airflow increased
Cant wait to see the results from your setup
Kerry
Kerry
#485
Kerry
Kerry
#487
I will have two 1.5" stainless steel pipes running on the passenger side frame rail. one pipe will be cold water feeding the two upper water ports and the other will be hot return water from the bottom ports. its -12an off each port on the block. so both top ports will go to one pipe and both bottoms will go to one pipe. the pump is a 50gpm from jegs. heres my Picasso like drawing
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880013/imafuckingartist_zpsc91b160d.png)
#489
hotside and coldside are all complete. just waiting for my 60mm jgs wastegate to come next week then I can weld the flang on and attach it. got it for $375 from a member on here.
almost thought about keeping my down pipe this way. looks kinda cool
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zpsd99445cd.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps6dc3ecf3.jpg)
painted and wrapped my hotside. can still feel the itchy **** on my arms. reminds me of hanging insulation.
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zpsd2519df2.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps040faca2.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps61c29280.jpg)
also fabbed my bracket for my alternator and tensioner. just cross my fingers I don't have alignment issues and throw belts
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps86be2d1e.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps0d9f62c9.jpg)
heres how I actually did my downpipe
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps6667a7b6.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps125e976a.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps13404ffd.jpg)
and now just some more pictures.
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps37a9c303.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps3cad9e44.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps0ed56886.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zpsac66c145.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps6d018259.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps3732ba16.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zps66810a41.jpg)
![](http://i93.photobucket.com/albums/l74/NJ54880/NJ54880014/image_zpsc4ca0772.jpg)
im going to get a huge parts list so I can finish fuel system and tranny lines next weekend and get this thing running. once I sell my lf85 I can order the rest of the **** I need to finish this. im busting my *** to finish it by the 21st to put it in a local car show.
#492
just ordered $1600 worth of **** to finish it completely besides a couple small things from napa. will be driving by this weekend and hopefully completely finished (for now haha). car show starts in a couple weeks gotta have it driving by then. ill update later in the week. going to get more done Tuesday.
#494
Thanks I'll definately be contacting you this weekend or next week. This carb wasn't setup for my motor it was on a turbo lq4 so I'm going to need to tune for sure. Just going to run low boost at first so I don't kill this motor. What base fuel pressure should I run with vacuum unhooked on the regulator?
#495
#496
I have 2 of my blow thru cars on Superior airflows website I ran their bonnet also and used to add vent tube extensions that were routed to the front of the bonnet and had a flare on the tubing it allowed me to run a much smaller jet and the airflow into the vent tubes would raise the bowl pressure and make up for the smaller jets it ran really clean on the street and still made 1000 plus rwhp also keep the power valves in it if you want to ride the street im guessing your carb already has the restrictor circuits modified??????? I had drilled out the passeges behind the poer valve and put in small allen plugs that I would drill and use as jets so you could tune the fuel enrichment when vacuum was loss
#498
Looking great Nik! Seems to be alot of questions about your carb, being the previous owner of your carb I might as well tell the story on it. I bought the carb new as a blow thru quick fuel for regular gas, later on in my build I decided to go e85 so I sent the carb to Eric at horse power innovations in michigan heres the link www.horsepowerinnovations.com . From what i remember he changed the booster rings and did a bunch of machining to the metering blocks and put there style of power valve in it, I asked to set it up to support 1000hp. When the carb was returned to me I bolted it on and fired up the motor, it idled at the afr that he said it would and revved real crisp and fast, it was spot on to everything eric said it would be. Iv had this carb on a 6.0l and a 5.3l and pretty much never had to change anything on it however i did put the dual needle and seat float bowls on it just because i scored a good deal on them. As far as details on the mods on the metering blocks , I have no idea whats been done, thats why the pros were paid to do them, Eric specializes in blowthru e85 carbs and havent ever heard anything negative about there work. Nik! we need a start up vid! soon!
#499
