LS9 heads compared to aftermarket for boost
Old Sep 19, 2012 | 09:37 AM
SUPERBOOST's Avatar
Default LS9 heads compared to aftermarket for boost
Anyone know much about the ls9 heads,I've heard they have a thicker deck than other factory heads.Is this true?How would they work compared to trickflows or other aftermarket heads for a street strip turbo motor.?
Old Sep 22, 2012 | 09:06 PM
fastsspr's Avatar
good question any info.?
Old Sep 22, 2012 | 09:17 PM
westtexasbuff's Avatar
The LSA, and LS9 heads are roto cast which produces a much stronger part than conventional casting. They also use a higher grade alumnium than the L92 heads. If you've ever looked at an L92 casting and then a LSA/LS9 casting you can tell the difference in quality. LSA/LS9 practically have no porosity in the casting. The LS9 heads however use 12mm bolts which no other LS engine uses, the LSA uses the conventional 11mm head bolts. LS9 heads do have a slightly thicker deck compared to other stock heads. I'm using LSAs on my build.
Old Sep 22, 2012 | 09:35 PM
boosteds10's Avatar
What is the comparison as far as cost also?
Old Sep 23, 2012 | 11:55 PM
What compared to what? LSA heads can be had way cheap. $340 shipped brand new bare for the pair.
Old Sep 24, 2012 | 02:21 AM
thehazz12's Avatar
Um...WHAT??? Do tell! Is this straight from GM? NEED MORE INFO!!!
Old Sep 24, 2012 | 09:24 PM
thehazz12's Avatar
TTT. westtexasbuff step back in! Need more info on $340 LSA heads!!!
Old Sep 24, 2012 | 10:20 PM
Call http://www.superchevyperformance.com Tell them you want bare LSA heads. They don't have them listed on the website, but if you call they can ship them to you directly from GM.
Old Sep 25, 2012 | 06:19 PM
coolmanvette75's Avatar
Do they come with valves for that price???
Old Sep 25, 2012 | 06:41 PM
helga203's Avatar
He mentioned bare.
Old Sep 25, 2012 | 09:12 PM
fastsspr's Avatar
who have a part number for them?
