how hard is aps tt install?
Old Sep 27, 2012 | 05:55 PM
TermnEatr's Avatar
Default how hard is aps tt install?
Debating on if I should do it myself or pay my tuner? He's not cheap at all but he does great work. I'm replacing the motor as well so ill have the motor and all out as well... And I have a lift just looking for some opinions thanks
Old Sep 27, 2012 | 06:48 PM
Somebody09's Avatar
I didn't remove my engine, so the hardest part was the k-member. Everything else was easy. It was straight forward. Took a while though. Did the easy stuff first, washer fluid reservoir & over-flow, then FMIC, and so on. Needed the car M-F at the time so I installed it myself over several weekends.
Old Sep 27, 2012 | 08:34 PM
TermnEatr's Avatar
Good to know
Old Sep 27, 2012 | 08:49 PM
Pete91's Avatar
Haha...... It's very time consuming and much easier if you pull the motor and I'm not talking about from the top lol. The kit is a very nice piece though wish I could have one.
Old Sep 27, 2012 | 09:04 PM
KWIKKAR's Avatar
Just take your time and lots of it. K member is a bitch by yourself. I did mine on a lift, not a fan of jack stands. Is it a new kit or used??
Old Sep 27, 2012 | 09:37 PM
TermnEatr's Avatar
It's all brand new with the LG upgrades planning on a 410 from aes soon to go with it.
Old Sep 27, 2012 | 10:34 PM
offaxis's Avatar
thats gonna be a killer setup. Good luck with it.
Enjoy
Old Sep 28, 2012 | 12:32 AM
itsslow98's Avatar
If the motor is out anyways i see no reason not to install it yourself.
Old Sep 28, 2012 | 07:08 AM
TermnEatr's Avatar
Thanks for the opinions guys can't wait to get the ball rolling with the build...
Old Sep 28, 2012 | 07:54 AM
Somebody09's Avatar
To save money!? lol not everyone wipe's his *** with Benjamins
Old Sep 28, 2012 | 01:35 PM
Louis's Avatar
Read.The.Manual..... thats all I can tell you. youll take MAJOR steps back if you try skip steps
Old Sep 29, 2012 | 03:46 PM
TermnEatr's Avatar
One more ? On the kit I know I will need the msd aps starter and a bmr crossmember now is it just any crossmember or is there a specific one I need?
Old Sep 29, 2012 | 05:12 PM
SLOWWZ28's Avatar
Call bmr they have two now aps specific! One for more room for inlets and one with more room for larger bb turbos! I have the original that the aps manual calls for and the one for the larger inlets (not installed yet) looks like a ton more room for inlet tubing!
Old Sep 29, 2012 | 06:17 PM
TermnEatr's Avatar
Are u talking about the k member? I have the k member ... On the site it says not included are the msd starter and also a bmr crossmember that will be needed
Old Sep 30, 2012 | 12:39 PM
TermnEatr's Avatar
Anyone ?
Old Sep 30, 2012 | 10:04 PM
itsslow98's Avatar
Reading comprehension fail lol
Old Oct 1, 2012 | 03:09 AM
Ls-x's Avatar
Hello ,
I have the msd starter but i didnt installed it yet because the oem works great with only heat shield.
so imo if you still dont have it dont buy it until your starter fail
Good luck.
Old Oct 1, 2012 | 04:12 AM
poloaa009's Avatar
Old Oct 1, 2012 | 06:26 AM
ToxicWS6's Avatar
I havnt done an APS kit but ive done a bmr turbo kmember, with a pift doing it urself shouldnt be horrible, did mine with a friend on jack stands in my driveway, so hilding up and tryin to keep it alligned while putting bolts in were a bitch, even with a jack helping it, just get the little dowels/alignment pins in there holes and u should be good
Old Oct 1, 2012 | 07:46 AM
Somebody09's Avatar
Yeah, you're right, but that's okay. My heart will continue to pump blood through my arteries and veins regardless.
