Timing? Tuning?
Old Oct 11, 2012 | 04:23 PM
99VetteFRC's Avatar
Default Timing? Tuning?
I am trying to learn some things about tuning on my Chevelle. I was wondering what you guys with stock engines with turbos are running for "Hi Octane" timing tables. My car seems to be sluggish off the line and I am wondering if adding some timing to the lower end of the table would help?
Old Oct 11, 2012 | 05:01 PM
67Firebird455's Avatar
Are you getting any KR when logging? What do your tables look like now?
Old Oct 11, 2012 | 06:46 PM
oange ss's Avatar
are you using a custom OS ? post the timing table
Old Oct 12, 2012 | 04:41 AM
99VetteFRC's Avatar
I will run a log this morning. Here is a copy of the tune.
File Type: hpt
Old Oct 12, 2012 | 07:30 AM
99VetteFRC's Avatar
I added a couple degrees of timing below 3200rpm and logged a pass through first and second. I lifted as I shifted into third. I'm trying to get the car to make some low end to make up for turbo lag.
File Type: hpt
File Type: hpl
Old Oct 12, 2012 | 08:03 AM
Strokinit383's Avatar
What effect did the timing bump have on accelleration? At work and cant open the scan. Take this with a grain of salt, because I am new to tuning. Seems like you could just bump your timing a few degrees at a time until you start to see knock and then back it off a tad.
Old Oct 12, 2012 | 08:51 AM
oange ss's Avatar
what's the A/R on the turbine housing ? those downpipes look awful tiny...
Old Oct 12, 2012 | 09:00 AM
99VetteFRC's Avatar
The bump made it have more power before boost.
Old Oct 12, 2012 | 09:02 AM
Sales@Tick's Avatar
https://ls1tech.com/forums/forced-in...-60-times.html
https://ls1tech.com/forums/forced-in...pool-time.html
Old Oct 12, 2012 | 09:03 AM
99VetteFRC's Avatar
I bought those a year ago and don't remember the numbers, but cast into the housing it says A/R70. the turbo outlets are 2.5" so I used 2.5" pipe to make the down pipes just until they meet the 3" exhaust I reused from the BBC. There is true duals so each half of the engine see 2.5" exhaust.
Old Oct 12, 2012 | 10:18 AM
oange ss's Avatar
I thinik you're referencing the compressor housing. Most chinese T70's I've seen are .68/.84 on the trubine side.
Old Oct 12, 2012 | 03:19 PM
99VetteFRC's Avatar
Thanks for the links. At least I am on the right track.
Old Oct 12, 2012 | 08:58 PM
98Camarod's Avatar
You have a 1 bar OS applied......
Old Oct 13, 2012 | 04:29 AM
99VetteFRC's Avatar
Yeah, not to sure how I did that.
