Some turbo questions? TC76 low boost, turbo lag?
Old 10-15-2012, 09:29 PM
sweet99ss's Avatar
Default Some turbo questions? TC76 low boost, turbo lag?
So one of my friends who has always had turbo cars was telling me that I'm going to have bad boost lag if I run a turbonetic tc76 turbo on 6lbs of boost and says it won't even hardly be faster? My goals are not real high to start out with the turbo. I plan on pulling out the 224r cam for funds for the turbo also. There are a couple of reason's I want to run only 5-6lbs of boost and probably make around 450-480 rwhp. Mainly bcause I want the tranny to last a little while on boost and I only have 37lb injectors at the moment. So the motor is going to be stock internal, stock heads & head gaskets. Now hopefully knowing all the above some of you can answer my questions...
Questions
1. Will I have bad boost lag with a TC76 turbo on 5-6lbs of boost?
2. How much power can I expect to make on stock motor with 5-6lbs of boost?
3. Will I have the power to trap mid 11's@120mph+ on 5-6lbs?
Old 10-15-2012, 09:56 PM
SPRAYED 01's Avatar
Your friend has no idea what he or she is talking about. a tc 76 on a 346 spools very fast, almost no lag. Doesn't matter if a controller is set to 6psi or 20psi it would get to 6 in the same amount of time. You will notice a huge power increase even at 6psi. Probably around 100whp more. I don't think you will have a problem going 11s.
Old 10-15-2012, 10:05 PM
LT1RAY's Avatar
This. A TC76 (68mm turbine .96 a/r) will spool very fast and your friend doesn't have a clue. You should have no problem hitting 11's with a stalled auto on 5-6psi. Goodluck with your build.
Old 10-15-2012, 10:09 PM
sweet99ss's Avatar
Kinda what I thought. He has had 4cyl cars with turbo's. Honestly I have an 11 sec car now as i went 12.2@113 last time to the track with a 1.98 60ft. So if I put some mt's on it i'm sure it would do 11.8's pretty easy. I do plan on taking out the cam when I go to put the turbo on though. My goal would be to run mid 11's@120+ on 5-6lbs. The car before the cam did 12.3@109 with a 1.76 60ft.
Old 10-15-2012, 10:51 PM
tiznodd's Avatar
My LQ4/76mm on 6.5 psi made 500rwhp through a 6 speed. I'm sure it would be less with an auto, but to say it's not noticeable is absurd. Honestly, that's the setting I drive around on most of the time. With street tires, once I start getting into the 10+ psi range, I have to really focus on what I'm doing because it will blow the tires off pretty easy.
Old 10-16-2012, 12:08 AM
LT1RAY's Avatar
Big difference between your turbo and the OPs. 68mm turbine vs 84mm turbine will produce quite a big power difference on 6.5psi.
Old 10-16-2012, 01:10 AM
sweet99ss's Avatar
Noob question lol. Wich would produce more power at 6.5 psi the 68 or the 84mm?
Old 10-16-2012, 01:28 AM
tiznodd's Avatar
I do agree that my turbo will make more power, however the differences would be more pronounced at higher power levels. Also, my turbine is 75mm on the exducer, which is where the tc unit is measured. The point of my post was simply that 6 psi is noticeable.
Old 10-16-2012, 02:02 AM
got-a-ls1's Avatar
i think your friend just wants you to be slower then him... lol
Old 10-16-2012, 07:00 AM
c0ncEpT's Avatar
I don't think you'll have a problem hitting your goal. Superman09 went 12.0 @ 118 with a STOCK car and 5 PSI. Stock converter, stock motor, stock rear, stock everything. His car only made 420RWHP at the time.
Old 10-16-2012, 07:56 AM
Ryans99ls1's Avatar
Don't listen to him. my tc78 hits 12lbs at 3500rpm. Instant spool with a lil brake boosting too.
lag isn't really a product of how much boost you are running, its more about the size of the turbo and the size of your motor. the tc76 is a smaller turbo and our cars move a lot of air through that small turbine. its gonna spool
Old 10-16-2012, 08:13 AM
LS1Tech Sponsor
Superman09's Avatar
Over 6 years ago!
You will definitely feel a TC76 on low boost! A good idea would be to ask Dave or check out his thread on here, 1999Black_Z28. He runs the Huron Speed turbo kit with a TC78 on 5-6 psi and loves it! It will also spool almost instantly for you!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 10-16-2012, 08:44 AM
sweet99ss's Avatar
Once the turbo is on all I will really have is prc .650 springs and a ported throttle body... Other than that the engine will be stock. I think when I pull the 224r I might just put in an ls6 cam instead of stock though... Not 100% on that though
Old 10-16-2012, 08:56 AM
sweet99ss's Avatar
Originally Posted by Superman09
Over 6 years ago!
I've asked him alot of questions about his setup, read his build thread, AND watched his vids on 6 psi and that thing looks like alot of fun. He actually made my decision to buy the huron speed kit after watching his vids and getting some info from him. I can't wait to see what he runs when he gets it to the track!
Old 10-16-2012, 02:38 PM
Ryans99ls1's Avatar
i would leave the 224r in with the turbo.
Old 10-16-2012, 03:31 PM
1999Black_Z28's Avatar
Hopefully I will find out this weekend
I did some rough calculations based on the mph I ran NA (with the 317 heads and LS6 cam it ran 107mph) so I expect to run around 118 mph at 6psi. 118 isn't much faster than my old heads cam setup but the torque curve is so fat that the car feels a ton faster on the street.
It doesn't really matter too much to me anyways because I found a really good deal on an e-bosst street so next spring my car will be getting more boost!
Old 10-16-2012, 10:08 PM
Johnv's Avatar
Plus 1 on this !
will make more power than a stocker or LS6 and will lower dynamic compression , which is not a bad thing on a std bottom end.
Old 10-16-2012, 11:16 PM
sweet99ss's Avatar
Originally Posted by Johnv
Plus 1 on this !
but harder on my valvetrain.. I don't want to have to pull springs every 10k to check them. I'd rather leave an ls6 in there and not worry about the springs
Old 10-17-2012, 05:14 PM
Johnv's Avatar
A TR224 is not that much more aggressive than an LS6, and both will need decent valve springs with boost.
no need to check valve spring every 10k at that boost & cam lift if you use a good set of springs.
Old 10-17-2012, 06:04 PM
jridenour31's Avatar
Lift may not be much higher but I'm sure the ls6 lobes are considerably more mild than the 224.
Quick Reply: Some turbo questions? TC76 low boost, turbo lag?
