Twin 6262 T/A - Turbo Joe twin kit/ 370cid 6sp street car
#505
I drive mine on the highway for 70-80mi trips all the time. 28" tire and 3.27 gear. Not sure I agree at all that overdrive is needed with this type of setup. Now many other setups for sure but the turbo cars end up needing a lot of gear/tire which works out with a glide.
3.27 + 28" tire
65mph is a little over 2500rpm
But IIRC he wants overdrive still I think?
3.27 + 28" tire
That's probably why you only tach out at 2500 rpm's.
The od auto's also have a lower first gear and more gear spread to help the mileage too and keep the car in the powerband.
That's why a lot of the OEM car manufacturers are going to more gears in the transmissions now. The New Hellcat has 8 speeds, the New C7 and Z06's have eight, there are 9 speeds coming out and a ten speed in the works too.
Once again, just my opinion.
#507
Actually, the tire height does effect cruising rpm quite a bit. 3.27 gears with a 28" tall tire isn't bad at all though. I use to cruise all over in my 70 Chevelle with a 4.10 gear and a 28 tall tire. Those damn Flowmasters would resonate me right out of the car on long trips though!
I think if OP is going auto just use the TH350 in the T/A since it is a heavier car and he already has it and get a PG for the Mustang since it should be lighter and more track oriented, unless of course he is set on getting a 4L80E which would also be a great option.
Just my opinion.
Just my opinion.
#509
I have to say I like this car over the mustang build and even though some people think the auto is less fun, with a nice stall itll move a bit better.
off topic, the last few posts have been entertaining and should continue, that is all
