Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
Old 07-07-2013, 12:26 PM
  #521
LS1Tech Sponsor
Superman09's Avatar
Still have some in stock, inventory is now low so get them while you can!!!!
http://shop.huronspeedproducts.com/T...urbos_c132.htm
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 07-07-2013, 04:32 PM
  #522
HolyShiznit's Avatar
Woohoo! Thanks!
Old 07-08-2013, 08:44 AM
  #523
LS1Tech Sponsor
Superman09's Avatar
Originally Posted by HolyShiznit
Woohoo! Thanks!
Going fast!
__________________
Old 07-09-2013, 09:08 AM
  #524
LS1Tech Sponsor
Superman09's Avatar
Also have the BILLET wheel 7575's in stock in both .96 and 1.15 a/r
__________________
Old 07-09-2013, 04:46 PM
  #525
Matt00's Avatar
How much are these? Could you pm me please?
Old 07-09-2013, 06:15 PM
  #526
The prices are posted on Huron Speed's website.
Old 07-09-2013, 08:34 PM
  #527
Matt00's Avatar
Thanks I just saw that when I posted it. The link didn't work for me.
Old 07-10-2013, 11:44 AM
  #528
LS1Tech Sponsor
Superman09's Avatar
Here is an updated list of in stock turbos, they are going fast, get them while you can to prevent any back-orders or delays.
On the shelf, ready to ship!!!
2- cast 7875 .96 ar
1- billet 7575 .96 ar
1- billet 7575 1.15 ar
__________________
Old 07-11-2013, 01:13 PM
  #529
LS1Tech Sponsor
Superman09's Avatar
Who else needs one?
All orders SHIPPED!
__________________
Old 07-13-2013, 11:02 AM
  #530
LS1Tech Sponsor
Superman09's Avatar
Billet 7575 .96
Billet 7575 1.15
IN STOCK available for immediate shipment!
__________________
Old 07-13-2013, 11:29 PM
  #531
LT1RAY's Avatar
Old 07-14-2013, 07:08 AM
  #532
LS1Tech Sponsor
Superman09's Avatar
Car sounds great Ray! Glad to see you are enjoying both the 7875 and your Huron Speed kit
__________________
Old 07-14-2013, 03:06 PM
  #533
Denali08's Avatar
Does the 7875 come in billet?
Is it a direct replacement for Magnum T76 Q-trim and how much of an improvement is expected on a 5.7L LS1?
Which is better 7675 billet or 7875 cast as far as HP?
Old 07-14-2013, 03:23 PM
  #534
LS1Tech Sponsor
Superman09's Avatar
Yep, direct replacement with the t4 flange, 3" v band downpipe, 4" compressor inlet and 2.5" outlet!
The billet unit offered for this turbo is a 75mm wheel. They offer a 76mm and 78mm wheel but they are cast, no billet 78. The billet 75mm will provide the highest hp capability and efficieny followed by the cast 78.
Improvements greatly rely on your setup and boost pressure, but a terrific upgrade from a magnum turbo or anything else with the small 65 or 68m turbine. Will allow for much more hp potential as well as efficiency allowing much lower drive pressures!
Old 07-14-2013, 03:48 PM
  #535
Denali08's Avatar
How is the billet 7575 compared to Precision PT-7675? performance wise on same 5.7L LS1. Stock intake with cam and 9.5 CR. Boost is 18 psi.Through 3" DP and 3" cut out open.
Old 07-14-2013, 04:23 PM
  #536
LS1Tech Sponsor
Superman09's Avatar
Units certainly are comparable as we keep both the Turbonetics and the Precisions in stock!
Bang for the buck I would go with Turbonetics as you can get a Billet, Ball Bearing Turbonetics for the price of a Journal Bearing Precision. However both are great units and a toss up, mainly brand preference! Let me know what you like and we would love to get you set-up!
__________________
Old 07-14-2013, 05:00 PM
  #537
Denali08's Avatar
Which will be better option, .96 open or 1.15 divided?
Old 07-14-2013, 05:19 PM
  #538
LS1Tech Sponsor
Superman09's Avatar
That depends on your set-up and which will suit your needs better. If you want to shoot me a PM with full specs on your engine combo, trans set-up, and use of vehicle I can give you my recommendation!
The .96 will spool quicker than the 1.15, but the 1.15 ar will carry power up higher in the RPM range. Typically the larger ar will work well with set-ups with large camshafts and converters that get into the upper rpm's quicker and want to be spun higher. Otherwise, the tighter ar's work great in street applications with a more moderate set-up to help get into boost quicker.
__________________
Old 07-15-2013, 06:45 AM
  #539
LS1Tech Sponsor
Superman09's Avatar
Just ONE 7875 cast wheel unit left! It is a .96 a/r
I have billet 7575's left in both .96 and 1.15 a/r's
__________________
Old 07-16-2013, 09:01 PM
  #540
LS1Tech Sponsor
Superman09's Avatar
ONE 7875 .96
ONE Billet 7575 .96
TWO Billet 7575 1.15
Left in stock, get them while you can!
__________________
Quick Reply: Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
