Sloppy Mechanics guide (wire and fire ms1 and MSD6010 LSX)
Old 01-05-2013, 11:19 PM
  #81
Sarg's Avatar
Nice! Are you planning to get an engine dyno or just be able to start them?
Old 01-06-2013, 12:02 AM
  #82
Moderator
denmah's Avatar
just to start em and see if they rattle lol
Old 01-06-2013, 01:43 AM
  #83
superbean's Avatar
Id like to see some info on the timing aspec of the setups using the MSD box. Thanks a bunch for the post.. I really think this is the way I would want to go for my setup!
Old 01-06-2013, 11:02 AM
  #84
3pedals's Avatar
can the MS1 datalog? I really want to put a MS setup together, but if i do I want datalogging.
I read that the MS3 can datalog, but is it as simple to wire up as the MS1/MSD? also I am very comfortable with the MSD ignition box, can an MSD/MS3 combo be effective?
Old 01-06-2013, 12:58 PM
  #85
bdonn8484's Avatar
well i thought i was going the carb route but after finding this gem of a thread it quickly changed my mind and will be going FI. Merica **** ya
Old 01-06-2013, 01:57 PM
  #86
Moderator
denmah's Avatar
all of the megasquirt boxes can datalog with a laptop.
also EFI source has a hand held datalogger that records right to a memory card, i will be getting one next week and i can show you guys! its badass
msd/ms3 can work but MS3 does full sequential fuel and spark and it would be a waste of its capabilities and money
Old 01-06-2013, 02:03 PM
  #87
Moderator
denmah's Avatar
quick guide to installing a IAT sensor in a truck intake, on a Megasquirt swap car.
reason for this being that the IAT sensor is built into the MAFS on LSX cars, so when you swap em, you need to add a IAT sensor from another GM car, i like to cut them out of the 3800 buick's or a blazer or something v6 similar, then i remove the evap solenoid. Really this serves two purposes as that Evap noid is barely in there and would probably leak anyway when boost hits it....
i open up the hole with a drill, or rotary cutter, dremel etc, till it just fits but very tightly and then i cover the sensor with some RTV for piece of mind, even though it probably doesnt need it, i like to think it lubricates it while i hammer it in lol..
then i unplug the pigtal and hammer it in with a dead blow, or mallet etc.
here you can see its JUUUUST in the line of the intake stream but barely, so it wont ab struct, but it fits in there great.
Old 01-06-2013, 02:04 PM
  #88
Moderator
denmah's Avatar
Old 01-06-2013, 03:09 PM
  #89
Moderator
denmah's Avatar
edited the very first post to contain downloads for the 6010/ms1/micro2
Old 01-06-2013, 04:44 PM
  #90
tennerv8's Avatar
I just did this IAT install on my truck intake. I had a screw in IAT though. Mine ended up poking down a bit farther into the intake stream.
Old 01-06-2013, 06:08 PM
  #91
05_quick4door's Avatar
This is how I did mine. I made it out of an old aluminum oil pan that was in the way of a rod.
It houses the map barb and a $17 sensor from auto zone (pnSU107). Slap alittle rtv pookie on it and call it Shirley
Old 01-07-2013, 06:48 PM
  #92
bdonn8484's Avatar
I seen that you recommend the 80's for the injectors but your also running a turbo engine. I will be running a 6.0 with a cam and i have a vic jr intake that will have an elbow and a 90mm TB will i need injectors that size or can i go with something smaller?
Old 01-07-2013, 07:00 PM
  #93
Moderator
denmah's Avatar
stock truck 40lb injectors will be plenty, we made around 400whp with stock 40s through an automatic. if you wanna go NA
Old 01-07-2013, 07:01 PM
  #94
Silver Sleeper's Avatar
Hey Matt, im going to install my screw in IAT sensor in the freeze plug i used to block off my EGR opening in my intake...whats your opinion on this?
thanks
Trevor
Old 01-07-2013, 07:06 PM
  #95
Moderator
denmah's Avatar
anywhere will be fine honestly haha im just showing where i fit a stock 3800 junkyard sensor
Old 01-07-2013, 07:08 PM
  #96
cool...yeah whatever works...lol..there seems to be several ways to do it..
Old 01-07-2013, 07:12 PM
  #97
BTW, we have a new LSX section on our southeastern foxbody website...several people have given props to you with doing the LS swaps on there! you are somewhat famous..lol
Old 01-07-2013, 08:30 PM
  #98
Moderator
denmah's Avatar
haha thats funny!
Old 01-09-2013, 01:36 PM
  #99
Moderator
denmah's Avatar
im going to get some video for you guys and more detail on this neat product by EFI source, its a hand held datalogger that records right to a micro SD card, you just push the button in the car to make datalogs! no more laptop in the racecar! pretty neat product, right now its for MS1 extra code ECUs only, like the ms1 i use with the 6010 combo, im going to be testing it out on some of our cars and seeing how it works and showing you, it will be for sale shortly on EFI sources website and their ebay store.
Old 01-09-2013, 03:17 PM
  #100
3pedals's Avatar
Can it log extra inputs beyond the EFI sensors?
I want 2 speed sensors and iat sensor, and maybe something else��
Quick Reply: Sloppy Mechanics guide (wire and fire ms1 and MSD6010 LSX)
