How much to gain from S475 to S480?
Just trying to figure out if it is cost effective to spend 300 for a 5mm larger turbine or not.
I don't think I am running into back pressure issues as it only takes 22psi on the gate to make 20psi at the manifold. I think the compressor is just not moving enough air currently.
What does your stang weigh with you in it...<3200lbs?
Are the other aspects of the tuneup the same? Or did you raise boost and lower timing?
I wouldnt go bigger than the 83mm compressor with that turbo as a single. The 88 works better with the 96mm turbine on much smaller inch applications. Seen higher than expected backpressure as a single. For that its best to go to the S500 chassis.
