stock 5.3 goes 8.89 @ 157
Old 12-02-2012, 08:25 PM
JAX04's Avatar
Congrats man!
Im guessing you know Blake? lol
Great runs, congrats on the times!
Old 12-02-2012, 08:43 PM
Sarg's Avatar
Congrats! I forwarded the link to a buddy of mine who is reworking a 83 S10 with a L33 and twins.
Old 12-02-2012, 08:47 PM
silver_82's Avatar
Originally Posted by JAX04
Congrats man!
Yeah, ive done a bunch of welding for blake and nick both.
Old 12-02-2012, 08:51 PM
tom robison's Avatar
what rpm do you pull to? and what a/f do you run with e85? I seen your truck at rpms track rental at muncie, but did not get a chance to take alook. I had the white t/a pitted a few down track from you.
Old 12-02-2012, 09:04 PM
TurboMonte100's Avatar
What are the advantages of the dominator over a stock ecm?
Old 12-02-2012, 09:40 PM
Sales@Tick's Avatar
My suspension comment was directed at the rear suspension, but if you still have rebound to give in the front(meaning you have clicks you can tighten still) then you don't need limiters yet. use the shocks until you have no rebound setting left and it's all the way full tight. Then use the limiters. That's always worked best on our drag cars for us.
I know some guys use limiters then run their shocks loose and end up cutting their effective shock travel in half in the front and wonder why it spins.
Good luck!
Old 12-02-2012, 10:01 PM
silver_82's Avatar
In the past ive used the limiters to cut out the wheelies and to bring the nose down during the run. Its always made runs with the front hangin way up in the breeze. Maybe I need to change the front spring rate too?
Old 12-02-2012, 10:06 PM
Sales@Tick's Avatar
It doesn't look like it's an issue so I wouldn't worry too much about it.
If it becomes an issue when you're really throwing a lot of power at it off the line you might want to look into getting your front shocks re-valved.
If your out of shock and you're needing the limiters then use them, but if you can use just the shock and utilize all of it's travel and pitch rotation then do it.
Old 12-02-2012, 10:25 PM
silver_82's Avatar
The stock ecu would have worked just fine but I didnt want to buy efi live, widebands, datalogger, and boost controller when I could just have all of that in one unit
Old 12-02-2012, 10:36 PM
That makes sense. thanks
Old 12-02-2012, 10:39 PM
Black98s10's Avatar
This truck is a beast. I'm doing twin 67's midmounted on my 98 rcsb.
Old 12-03-2012, 09:15 AM
  #32
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,127 Likes on 736 Posts
Truck was a total sleeper in person, I first saw you run it at Norwalk.
Old 12-03-2012, 10:42 AM
  #33
rotary1307cc's Avatar
Nice Chris! What was your 60 and other increments on the 8.89?
Our times are the same which is weird because i would think you would be faster from what looks like a much better 60 from you
My 8.89@157 was with a 1.44 60
Old 12-03-2012, 10:46 AM
  #34
gnx7's Avatar
Holley just came out with a traction control module also for guys running a smaller tire or more power. David Technologies maks it. www.moretraction.com The base unit is $599 and the best "self learning" unit is $999.
Great pass and running 8's in a fairly normal weight vehicle on the stock 5.3!
Old 12-03-2012, 11:03 AM
  #35
Super Moderator
Reckless's Avatar
Just amazing
Old 12-03-2012, 11:05 AM
  #36
silver_82's Avatar
I believe it was a 1.36 that was the first time at that boost setting and it stumbled a little midway into the run
Old 12-03-2012, 11:14 AM
  #37
Ahh
Yeah i bet that has a 8.6 in it as is with a 1.2x
Old 12-03-2012, 11:54 AM
  #38
Where you running your ic for this or did you have it off?
Old 12-03-2012, 12:39 PM
  #39
silver_82's Avatar
The IC was on it for that run
Old 12-04-2012, 01:16 AM
  #40
Ellsworth's Avatar
Im in FW all the time and I work in decatur. Do you go to liberty or ricerworld on summer weekends?
I've been to Liberty a couple times. Went to the tilted kilt and hung out a few times too, every year I meet more people, trying to find the hangout spots this summer though. thats cool you work in Decatur, my dad owns a shop there
Quick Reply: stock 5.3 goes 8.89 @ 157
