turbo 4.8 ?'s
4.8 stock bottom end, gap top rings at .035, use arp head studs, 243 heads ( i need help on valve spring sizes, i hear that the boost can cause valve float), ls9 cam, ls9 head gaskets, ls1 intake and throttle body, 120# smart fire injectors, truck manifolds, on 3 performance 76 mm turbo, i plan on running 15 psi of boost. If the thing melts a piston i dont care i just had this motor laying around for a yr now, i would like to sawp everything to a 6.0 later on. Any input? do's and donts?
http://www.alexsparts.com/products/L...PRING-KIT.html
$107 complete and they work great out of the box. The LS9 cam is $139 or something but you'll need another $300 or so in parts to make it work on your early motor. I'd think about the stock cam for now if you're really on a budget, the fuel system and suspension/brakes eat up a lot of your money.
