I just started wiring (running wires and trying to figure out what goes where)
the micro to a ls6 on a Airboat- I wanted to get it running without turbo's first then add them in as a part 2....... My question is should I upload a 'stock'ish tune instead of the preloaded turbo tune it came with?
Or will it run ok as is without BEWST????
Off to find a v6 maf plug this afternoon!
Thank you so much Matt. And everybody else that helps out around here.
Has anyone gone from running a 24x wheel then switch to a 58x? I understand all of the differences, but I was told that the 58x sensor can still be used with the 12V reference, rather than the 5V. Has anyone been successful doing this?
looking at a 5.3 turbo build for the street, dont know anything about tuning. is the microsquirt modded for lsx and the microsquirt trans controller a good street option or should i use the factory ecu and harness and pay someone to tune it. Also ive seen others saying that if you want A/C the micro isnt an option, why is this? Any help would be greatly appreciated as I am a complete noob to the whole fuel injection/tuning game.
i was looking at the micro with denmah's turbo tune and wire it yourself harness due to budgetary reasons. is the reason behind not using micro for street vehicles ie vehicles with A/C due to no idle air control? if so is efisources idle air control packade an option along side the micro? also have you used the micro for trans?if so how does it work?
I have not used the micro engine controller just simply because eventually I will end up using all the Gold Box features. The micro for trans works pretty much like OEM and communicates with all of their engine conttollers.
Man, I thought the point of the megasquirt was to be low cost !!. That box is near the price of a real controller.
$1250 for a brand new plug and plug harness and controller that does just about everything right out of the box is extremely cheap. Holley Dominator will run well over $2000 for some features and everything is an added cost from there to have more.
$1200 is half the price of the Holley Dominator, ProEFI, FAST, etc. But don't let facts get in the way of your mediocre, unfounded opinion.
Hah ! Holley HP efi is $1700 and can do everything and more. wideband included, self tuning, and massive holley factory support. Also is enviro sealed and can be mounted underhood. Whats megasquirt got for factory support ? If you understood code, maybe, but You don't know $hit.
But, Megasquirt has its place for those guys who want to spend hours looking thru the "help" forums and tinkering endelessly. It can be made to run with the best, no doubt. Just hope you aren't paying anyone for the dozens of hours it takes to do so.
The $1700 HP version offers traction control? Multiple progressive controllers? Because my $1200 MS3 Pro does that and a lot more. The MS3 is also in a sealed case that can be mounted anywhere...As was the $400 Microsquirt I ran before that.
But hey, keep telling yourself whatever you need to in order to justify paying more for less.
This was on a $400 Microsquirt btw..The nitrous kit on this car probably makes more power than your entire combo:
I think the full-featured Dominator version from Holley is great. My buddy runs one and loves it. But to sit here and dismiss Megasquirt based on random things you read on forums is just fanboy ****.
Haha. Technically I could do that, but so could any computer that can read a digital or analog input and pull timing/etc. I was actually going to use a laser rangefinder on the front of the car and an Arduino to tell the MS3 if/when to pull timing or even turn off the kit momentarily.
That pic was at a no-prep race and was actually the result of taking a little power out of it to get it down the track. It dead hooked and went on the bumper twice. But got a ****-ton of views on 1320video.
Awesome there boosted. Looks like you have some experience. As do I. Can we drop the insults ?
I never dismissed msquirt. I have used it . Its capable. But are we talkin race cars or street cars here ? Your shots look like the former. Is ultimate dragstrip power the measure of the efi units capability ? Or is overall ease of use and tuning also a factor ?
That box that was linked, that i commented on, does not look enviro sealed ??. So which version of the many beta firmwares do you run ? Aso does your box have an integral wideband controller ?
Yes, the basic holley HP box has 3 stage nitrous, wet or dry, fully progressive with airfuel limits and also fuel pressure monitoring. Built in wideband controller too.!. And yes it can do traction control with the davis box (seperate).
