How to Microsquirt fuel and spark your LSX swap (sloppy mechanics how to!) 8-10-13
#82
Ok, Im ready to buy the microsquirt and harness today to run my Gen 4 58x 5.3 but what needs to be done differently to run the 58x Denmah? How about anyone running say one set of injectors (93octane) then switching over to E85/alky on another set of injectors for dual fuel setup?
#83
for 58x i have not done it but you should just be able to switch the tooth count and then add in the cam sensor and it will know how to fire.
i have not done fuel table switching or secondary injectors with any of these setups, i cant answer those questions sorry
#84
Well that was just something that I was curious about. Can you find out what needs to be changed since you said somebody was running on the 58x with it or should I just call EFI source? I'm ready to get this thing running I'm only missing PCM and wiring harness which I'm doing myself. Later Clint
#86
When did the 5.3s go to the 58x? I have a line on a low mileage 2006 5.3 but not sure if I wanna mess with it if it is a 58x. I have a 2002 5.3 now I was gonna use but the #2 cylinder is ruined. Need to find another long lock stat.Thanks
-Shannon-
-Shannon-
#87
Thanks Matt, Ill PM him to see what I can find out. That MS3 Pro looks to be an awesome unit with a ton of features, boost control, traction control, extra injector drivers etc....
I don't know which year they swapped over to 58x but I know now that the L33 5.3 was built until 2007 and it was 24x. When I bought this LH6 5.3, I thought it was a L33 with 24x until I took it apart and it had a 58x wheel, then I noticed it had DOD and single bolt cam, it's a Gen4, which is supposed to be a stronger block. Im going to push it too it's limits so Ill find out.
#94
Good to know Tony, what did you have to do different for the micro squirt to run your LS4? I have a LH6 that I would like to put it on just hadn't seen anybody use it on the 58x wheel yet.
#95
