Out of curiousity why does everyone use 2.5" on the crossover pipe
Old 02-17-2013 | 06:51 PM
  #161
engineermike's Avatar
Originally Posted by Tjabo
Thanks!
So is it correct that it really comes down mostly to the ideal gas law, and the ignition of the air/fuel mixture really does nothing more than add temperature, thereby causing the increase in volume?
This is a case where the ideal gas law can be applied. The composition and mass flow are slightly different on the exhaust side, but close enough. If you know the temperature, pressure, and mass flow, you can calculate the density using the ideal gas law and convert that to volumetric flow and then velocity. However you CAN'T use the ideal gas law to calculate pressure drop through an inter cooler or temperature rise through the compressor.
And you are correct about the adding heat part. For simplicity, just assume the basic Otto cycle where you just add heat at tdc.
Old 02-17-2013 | 08:27 PM
  #162
Phil99vette's Avatar
7 Second Club
It would be interesting to see what your calcualtion says. Reguardless what the calculator says, 2.5" will support 2400hp and has on multiple cars. My calculator has worked for the last few years and seems to be right on when the numbers are within the sweet spot.
Old 02-20-2013 | 10:10 AM
  #163
LSXKE20's Avatar
Red face
Is that a single 2.5in charge pipe? Ie: single turbo?
Or 2 x 2.5in charge pipes? Ie: twin turbo.
Old 02-20-2013 | 10:48 AM
  #164
chuntington101's Avatar
Think its 2 x 2.5inch pipes will support 2400bhp.
Old 02-21-2013 | 10:13 AM
  #165
LSXKE20's Avatar
That makes sense. Ive seen 1200hp with 2.5in single turbo but on a jap engine.
Old 02-21-2013 | 10:34 AM
  #166
7 Second Club
2 - 2.5" pipes has supported enough power to go 164mph @ 3350 to the 1/8 mile. I have the same crossover on the car now but on methanol with a bigger turbo. Looking for 181-183 to the 1/8 mile.
Old 02-21-2013 | 11:10 AM
  #167
427's Avatar
427
That has 2.25 pipes running in a oval shape with the ends fed in. That thing came on boost very quickly on the engine dyno even though it had tons of area pre turbo. What car are you putting that in David!!
Kurt
Originally Posted by MIGHTYMOUSE
.... which leads us to my newest set up
Old 02-21-2013 | 01:05 PM
  #168
MIGHTYMOUSE's Avatar
out of my budget, just a pipe dream although looks more like a PIPE NIGHTMARE!
Old 02-21-2013 | 04:52 PM
  #169
Originally Posted by Phil99vette
... Reguardless what the calculator says, 2.5" will support 2400hp and has on multiple cars. ..
That's a great data point and proves that most people do overkill on the crossover pipes.
Most people don't realize that the pressurized exhaust gas pre-turbine is of far less volume than exhaust on your typical NA engine, so it doesn't need nearly as much flow area.
This makes me wonder what are the implications pertaining to the exhaust port and valve. Can they also be downsized? This may make sense if it means you can fit a larger intake valve in there.
Another myth is that the downpipe shouldn't be oversized because you lose velocity. I know quite a bit about turbines and can assure you that the downpipe can not be oversized.
Old 02-21-2013 | 06:44 PM
  #170
superstreeter's Avatar
Well now that Ive changed my mind to a 2.25" crossover,,where do I find mild steel 90 degree elbows with a 4" radius ? lol.
Old 02-22-2013 | 08:14 AM
  #171
68LS1WANNABE's Avatar
Are you measuring inside or outside diameter on the pipe? Also what wall thickness? Ive got some 2" stainless steel pipe. It is all food grade pipe. Its 2" outside diameter 1 7/8" inside. 1/16 wall. Will this work on a 5.3 with a t6 s475? Reason for using is I can get all pipe and bends for free.
Old 02-22-2013 | 08:21 AM
  #172
Sarg's Avatar
I was also kinda wondering what ID this was all refering to.
Old 02-22-2013 | 08:50 AM
  #173
Tjabo's Avatar
I've been calculating everything with 16ga wall other than possibly where I was trying to see if I could match some of Phil's numbers and I noticed he was using O.D. just to ballpark some things. Oh hell, I don't know, I might have been using I.D. for that too, I have the I.D. areas of all the different sized pipes on a paper here next to my keyboard. Haha....
I think Phil mentioned that he ballparks his calculations with O.D. just to be simple, and then works with I.D. when he's really fine tuning things.
Old 02-22-2013 | 12:24 PM
  #174
Sarg's Avatar
2.5" od sch 40 and 2.5" od 16 gauge would result in vastly different flow calculations I would think
Old 02-22-2013 | 12:27 PM
  #175
67Firebird455's Avatar
I agree, there's quite a difference between the two. 2.47" ID for SCH40 2.5", OD is 2.88" I believe.
Old 02-22-2013 | 03:00 PM
  #176
Tjabo's Avatar
I personally haven't seen anyone running giant pipe heavy like that for crossovers..... Is it common at all?
Old 02-22-2013 | 04:09 PM
  #177
Sarg's Avatar
Nope was just illustrating the difference of ID and OD with various gauges of piping. It was not something I was using.
Old 02-22-2013 | 04:30 PM
  #178
16 gauge is .0625 which is 1/16 thickness.
2.5" schedule 40 is .203 inch thickness.
Old 02-22-2013 | 05:13 PM
  #179
I was looking for 16 gauge 2.25 OD mild steel, it seems that everyone is sold out of loose 90 degree bends. Columbia River's mandrel broke down, that does 2.25 tubing...lol
Old 02-22-2013 | 05:57 PM
  #180
dmaxvaz's Avatar
Wolfe Aircraft in Michigan has them in stock and will make them to order
Quick Reply: Out of curiousity why does everyone use 2.5" on the crossover pipe
