LS3 blower and turbo cams are here
These are more slated for a positive displacement blower engine. I have other cams specifically for LS3/LS7 style heads with centrifugal blowers:
Stage 1 blower:
http://www.tickperformance.com/tick-...3-l99-engines/
Stage 2 blower:
Even those these say "LS3 turbo cams" I use them in everything from cathedral port to rectangle port heads. It's usually best to just contact me and let me guide you to the best profile for your combination.
Stage 1 turbo:
Stage 2 turbo:
Stage 3 turbo:
For those that have a unique combination of parts that truly need a custom grind there is always that. I've tried to cover as many combinations as possible to where an Elite Series cam will fit into just about everyone's needs, but there are always some that will need a custom cam.
Custom:
http://www.tickperformance.com/tick-...l-lsx-engines/
For those guys with VVT and AFM here are our delete packages:
VVT Delete:
http://www.tickperformance.com/tick-...or-ls-engines/
AFM delete:
I'd want a very smooth idle though. So it might be a bit too much ?
GT9 at present is super smooth and it's great. The lift just is a concern in the back of my mind.
I like more overlap with a centrifugal blower set-up as they are usually sized in such a manner that the added overlap actually helps power production and not hurt it. With the positive displacement stuff, I like to stretch the events out longer while keeping overlap to a minimum. It really helps shift all that massive low end torque up top where they like to run out of steam. Obviously the blower still dictates where it will run out of steam, but the longer cam events help keep it pulling just a little bit longer. With the added exhaust duration you gain peak power from taking power at peak torque that you had plenty to give, and sharing it with the higher rpm regions.
All that said, I have a better cam for your set-up:
234/250 .60x"/.59x" 116+4
But I dont think it will meet by smooth idle criteria, and it would struggle to meet the emissions testing I have to do every year. Two of the reasons I opted for the GT9, as it was safe in both respects...even if it does have very aggressive lobes.
The stage2 above seems it would be somewhere in the middle though
The Stage 2 uses very stable lobes which are semi-aggressive, but great for boost.
Im very traction limited so really do not need any more torque. Anywhere local I can race is just an airfield, so cant even get a sub 2s 60ft, and usually leaves black lines for most of the track.
My fast times are from a proper strip, although even that was 4-5 years ago, and was with the 4"
If anything though...with the current 3.825" LS2 and GT9 etc....it's probably performing better than it ever has.
But I know the lobes are aggressive, and I know a slightly bigger cam would see gains. But achieving those with my idle/emissions criteria dont always go hand in hand.
This is why I like to discuss with guys about their set-ups before just jumping into a camshaft because it worked well for someone else.
I just saw your PM Steve, I'll get to it soon.
You could probably get away with the PAC beehives, but I don't like chancing anything. You'd be best to run a set of BTR "Platinum" springs, or have me do you a custom cam for those springs like I did for Denmah and a few other members that didn't want to run a dual spring.
Honestly though, I'd have to review your current set-up, your current cam tune-up etc. to see if it'd be worth it to justify the cost and labor to swap cams. I'll be the first person to tell you if it isn't worth it.
Would one of those off the shelf cams work with these LSA's or would you recommend custom grind??
Strictly an 1/8 mile race car
If you don't mind shoot me a PM with your email and we'll work on something for him.
I have a standard ls376 and am looking to turbo charge it either twin or single.
I am looking for upto 600 rwhp from around 450 at present at low boost
I want to gain some low idle/ speed characteristics ( never been that happy with the 376) and even after as much mapping, that's the way it is.
Which cam would you recommend,? how would my current cam perform do you feel?
Also for this power increase for the street are any further engine internal upgrades recommended
Thanks
Thanks
The camshaft in a boosted combination will really depend on the turbo(s) being used, the operating range where your engine makes peak torque to where it makes peak horsepower, intake manifold used, cylinder head port volume, intake/exhaust valve sizes, weight of the vehicle, gearing etc. etc. etc.
