Help me choose a turbo.
Stock ls1 short block
AFR heads
Fast 102 intake
4:11 gears (which i will change to 3:55 or 3:43 when i do the turbo)
current stall is a circle D 4800 nitrous stall( which ill change as well)
~11:5.1 compression
what i had plan is to run the turbo on low boost with e85 and a meth kit while i build a 6.0 block i already have to a 408.
As for the fuel im thinking dual in tanks with e85? and im not sure on injectors yet, any suggestion would be highly appreciated.
To answer the other question, the reason im looking at those turbos is because my kit is set up for a t6 turbo, it actually was set up for a gt45/55.
My goal for the car is to make 1000+ RWHP to get into the 8's down the road, so i would like a turbo, which will allow me to grow as i upgrade the motor and fuel system. let me know what you think and thanks again for the help.
