denmah's commonly bought turbo car items (update 7-11-16)
Old 12-11-2014, 04:08 PM
  #441
Sarg's Avatar
Originally Posted by tonypaul
The one I got works very well so far....
I just had an ebay Emusa gate rust itself shut after about a year or so, but it is not daily driven.
Old 12-11-2014, 05:48 PM
  #442
cam
cam's Avatar
Ya Sarg I remember that hence why im inquiring further. That sounds great Forcefed but where? I cant find it, got a link by chance?
Old 12-11-2014, 06:52 PM
  #443
Sarg's Avatar
Just make sure and maintain it and lube it up with the nice nickel anti-seize.
Old 12-11-2014, 07:33 PM
  #444
Forcefed86's Avatar
http://www.ebay.com/itm/GM-CHEVY-LS1-LS6-VOTEC-SFI-STEEL-FLEXPLATE-168T-97-UP-/360651325299?pt=Motors_Car_Truck_Parts_Accessories&hash=item53f87e7f73&vxp=mtr
Old 12-12-2014, 08:09 PM
  #445
cam
cam's Avatar
^ Mint thanks!
How do the emusa products compare to Tial in terms of durability?
Old 12-12-2014, 09:00 PM
  #446
Sarg's Avatar
Not as well, but you could buy 6 of the 38mms for the cost of a single Tial 38. A little anti seize seems trivial when you think about that.
Old 12-12-2014, 09:03 PM
  #447
cam
cam's Avatar
I hear ya and that is very true re the $
Old 12-12-2014, 10:28 PM
  #448
Moderator
denmah's Avatar
Bingo lol
Old 12-30-2014, 12:52 AM
  #449
Mrpiercings's Avatar
Great thread
Old 12-30-2014, 01:31 AM
  #450
Cashbootytattoos's Avatar
Thanks for the info!
Old 12-30-2014, 06:19 PM
  #451
stacy moore's Avatar
JY O2 sensors what cars do you guys get them out of ?
I gotta make a trip to the Junk yard so i might grab a few of them while out there.
Old 12-30-2014, 06:56 PM
  #452
xx_ED_xx's Avatar
depends on which os pcm harness you are running, i just dealt with this recently
Old 12-30-2014, 07:17 PM
  #453
Using a 2000 cable truck PCM with a PSI standalone harness
Old 01-08-2015, 01:25 PM
  #454
Y2K_Camaro's Avatar
Great info. Denmah, this may have been mentioned already but if so I apologize I didnt see it, what size cam do you usually use?
In the VS Racing kit, are you using the standard GT45 that comes with the kit or one of the upgraded ones? What size is the standard one?
Old 01-08-2015, 03:04 PM
  #455
Moderator
denmah's Avatar
usually cheapest mild cam in the 205-220 lift area's
like the triple 12 from JFR or like this trickflow i am trying 216/220
i like to stay around 550 lift and use pac springs so i can use all stock stuff and not beat them up.
i have used a bunch of the "GT45" series turbos, on many different builds
the standard is the gt45-68mm
Old 01-08-2015, 06:32 PM
  #456
Y2K_Camaro's Avatar
Awesome thanks man. Do I have to call or email VS Racing if I want to upgrade to a bigger GT45? There is no option to select to upgrade on their site although it says upgrades are available.
Old 01-08-2015, 09:07 PM
  #457
Rise of the Phoenix's Avatar
The Denmah kit on the VS racing website, what else do you need to make it a complete setup? Is the piping in that kit all you need, and is it specific for a LS or do you have to cut it up and fabricate?
Old 01-09-2015, 08:04 AM
  #458
Moderator
denmah's Avatar
i would call him because his inventory changes alot, depending on what he has or what he wants to get rid of he might be able to give you a deal on things.
Old 01-09-2015, 09:40 AM
  #459
ryanleiker's Avatar
The piping kit is a universal one and only the cold side from the turbocharger to the intercooler to the throttle body. You will need another coupler to go from the 3" piping in the kit to the 3.75" throttle body inlet - either a straight one or a 90* dending on what will fit your accessories. You will have to cut up these pipes to fit your car.
For my car, I only ended up using 2 - 180* bends from the kit.
You will need to build your entire hot side setup from engine to turbo, which will cost you as much as you want to spend on material and fabrication.
Old 01-09-2015, 09:50 AM
  #460
So technically doing the cold side is much easier than doing the hot side? I guess that's why Huron Speed sells just a hot side kit.
Quick Reply: denmah's commonly bought turbo car items (update 7-11-16)
