Dual Fuel on the fly(87 and e85) on stock pcm's!
Old 03-20-2013, 01:19 PM
  #61
MaxxMitchell's Avatar
I got in some successful runs in TX on the dual fuel set up. and kept resetting my personal best in my car all weekend. I will post a video of some passes once I get through all the footage. It was nice not having to worry about buying E85 at TX2k when the local pumps ran out from the large amount of cars buying it sense I was full when I left KC and still had fuel to spare after the weekend was over.
Old 03-20-2013, 02:49 PM
  #62
Area47's Avatar
so when do i get to drive it?!?!
Old 03-21-2013, 08:36 AM
  #63
cause4panic's Avatar
No need to dry fire injectors, the pcm grounds the injectors to fire them.
Each set of injectors is powered by a relay. Pump gas injectors can be powered by regular ignition source, E85 injectors by hobbs switch or any other snake oil tricks.
  #64
Here is a video of it in action.
Old 03-21-2013, 10:23 AM
  #65
RedRocketZ28's Avatar
Congrats, Ryan!
Old 03-21-2013, 12:03 PM
  #66
js2fst's Avatar
Awesome job on car Ryan
Old 04-03-2013, 10:19 AM
  #67
TTOP350's Avatar
GM did a dual ECM on this and on of the 3rdgen bigblock camaro test cars they built.
http://www.gtasourcepage.com/91RoadT.../91transam.jpg
Old 08-22-2013, 02:15 PM
  #68
Forcefed86's Avatar
That is pretty trick. A friend back in FL did this in 2005 with pump gas and c16. Crspysqirl (sp?) I believe was his name on these forums. Worked great! I believe he used 1 stock pcm and stock injectors. Then stock ECM and HP tuners on the second set. It's been so long I don't remember. Maybe he will chime in.
Quick Reply: Dual Fuel on the fly(87 and e85) on stock pcm's!
